lq4 vs lq9
Old Jul 24, 2009 | 04:06 PM
SunOfZ's Avatar
Question lq4 vs lq9
ok guys so i should be picking up one of these engines in about a week or so to swap in my Z. the plan is to keep it stock for now. so what hp and torque numbers should i expect to put down once i do the swap? lq4 vs lq9 numbers?
Old Jul 24, 2009 | 05:14 PM
NemeSS's Avatar
depends on drivetrain used. but neither engine makes 400bhp
in stock form
Old Jul 24, 2009 | 06:53 PM
Gaunt's Avatar
I would like an answer for this too, but when I posted my thread in here, nobody gave a ****.
Old Jul 25, 2009 | 04:26 AM
SunOfZ's Avatar
haha i think i remember that post too
Old Jul 25, 2009 | 09:06 AM
00SSLS1's Avatar
the only difference is the pistons
Old Jul 25, 2009 | 09:47 AM
philntx's Avatar
Not entirely accurate. The 2000 LQ4 had Iron heads.
Old Jul 25, 2009 | 11:05 AM
00SSLS1's Avatar
true, I was thinking short block only
Old Jul 25, 2009 | 11:33 AM
LARRY01Z28's Avatar
In stock form its barley worth the swap from a 346.
esp. if you count the weight added.
Old Jul 25, 2009 | 11:36 AM
NemeSS's Avatar
nobody posted, because hp is subject to what other mods, drivetrain,etc. will be used with the motor.
the ratings for all the lq4/9 were about the same for each.
if using a bone stock engine, dont expect any more hp than what is rated.
if go with lt,ls6 intake, etc. etc. it changes the outcome of the engine obviously
Old Jul 25, 2009 | 11:46 AM
Gaunt's Avatar
Dually noted, but my post asked what did they put down (rwhp, not rated hp) in stock form through the F-body drive train (specifcally a stock auto).
I then linked to my thread in the Dyno/Bench racing section for people to post what it would make with my mods.
That being said, the engine is going in regardless
It doesn't help that some of my posts are longer than most books :/
Old Jul 25, 2009 | 04:36 PM
5_02ls1's Avatar
shoot me a pm with your plans goals.....ill try to help...
Old Jul 25, 2009 | 05:28 PM
SunOfZ's Avatar
so the difference in pistons alone, dished and flat top, accounts for no difference in engine output? or is it just very little? ive noticed a lot while looking for 6.0's that lq9's are a slight more expensive in price. is it worth paying the extra cash for an lq9?
Old Jul 25, 2009 | 06:43 PM
Gaunt's Avatar
Well there is a difference in power because the flat top piston produces a higher conpression ratio, which ends up as more horse power. Swap out the stock 317 heads with some smaller combustion chambered heads like ls6 heads or better, and you end up with an even higher ratio. I can't remember, but I thought the difference between the two motors was a whole point in compression?
