help with gm stock piston rings
Old Jul 26, 2009 | 04:00 PM
ml258-89iroc's Avatar
Default help with gm stock piston rings
i am freshing my engine and installing new gm ls1 std rings after a hone. i know which one are the bottom oil control rings. my question is about the top and secong ring. one ring has a dot which i think is the second ring and the one i think is the top ring has no markings on it. is this correct? thanks
Old Jul 26, 2009 | 04:39 PM
02b4ccamaro's Avatar
the one w/the dot is the second ring, the top "compression" ring is also the smaller of the two.
Old Jul 26, 2009 | 05:07 PM
98RedBird's Avatar
True.
Old Jul 26, 2009 | 05:56 PM
99Ls1fever's Avatar
Did you a engine rebuild kit or just piece it together?
Old Jul 26, 2009 | 05:59 PM
thanks for the help. that matches up with the gaps. i just peiced it together.
