anyone running around 11.5 compression
Tried cranking it with a, about 18" ratchet and wouldn't budge
Noticed the green light was not in the battery like it was when we unhooked it 3-4 weeks ago. Hooked up a charger (showed the charge was not full) let it go 5-10 min.
cranked again and ran for a second and shut off.
let charge more and started boiling right away.
So we gave up. I hope it's the battery. I work for a maufacturer and I will pick up a new one tomorow, if we don't get another 2 feet of snow that is. We make one that cranks 1000 amps that should fit right in.
If that don't crank it over and keep it running ????????????????????????????????????
thanx fellas
If it won't budge with a breaker bar you better look somewhere else. Sounds like something is binding up. What did you do to the motor? Is it new? Give us some more details.
I don't think the starter is the problem, I think it's the battery
heads, cam, headers, clutch, flywhhel, and bunch of other little stuff
thanx
Might be your battery too.
