Old School needs help with new gen3 engine
I have a 2003 6.0,a set of 2005 799 casts 5.3 heads,eldbrock victor junior intake for carb and a 6010 msd box.
This will be a weekend drag car and crusing car shows..the engine will have a stock lower end and the car will be automatic trans with a 3500 stall.I would like a recomindation on a cam&springs (that won't break the bank with a good sound and hp gain).Also which head gasget,6.0 or 5.3?Should the heads be cut?
I hate to ask for cam help but most of the posts that I read are about fuel injected engines.
First of all, do NOT cut the 5.3 heads...with the small chamber already the compression is going to go up going on a 6L. Im not 100%, but I think your going to want to use 6L head gaskets and not 5.3's...someone correct me if im wrong.
An off the shelf camshaft isnt going to be the thing for you, b/c they are mostly for fuel injected motors and that carb is going to want a much narrower LSA than the standard 112-114 the average FI cam is ground on.
I would say your going to want a 232ish intake and 236ish exhaust duration @ .050 and around .600 lift on a 108-109 or so LSA. Check out the newest Hot Rod magazine and they dyno (im pretty sure its a 6L) with 4 different Comp cams with FI and Carbs on each one...pretty good info and may be something you want to check out.
Also, you may wanna contact Predator-Z or Patrick G...both are members on here and do custom camshafts for these motors. I have seen good results from people using cams from both of these guys on FI motors but im sure they could help on a carbed one as well.
Hope this helps
What 6.0 (364ci) do you have? LQ4 (dished pistons) or LQ9 (flat-top pistons)?
Gaskets GM 6.0 MLS.
You'll also need to give a bit more info to spec a cam:
What type of auto tranny?
What exhaust setup? (from manifolds to back)
What gears in the differential?
Weight of car?
What rpm shifts?
str of stall?
basicaly the whole setup....
thanks for the quick reply guys
other than that you might have to open her up.
Chances are that its a LQ4 just because there more of them laying around, but i guess chances aren't good enough when you need piston to valve clearence.
As for springs there are comp 918's, PRC, and patriot. They all have good springs available.
Stock bolts are real funny in these motors it seems to me. Some people crank them to 7 grand for years and they live fine, others turn them 6200 and they fail. its pretty hit and miss seems like so I think the upgraded bolts are a great idea...especially while the motor isnt in the truck yet.
, there are many qualified sponsors and poeple on this board.
