228 Duration Camshafts On The Engine Dyno
Tuning has come a long way in the last few years. I think the LSA stuff is a matter of education. People spread the LSA because they are chasing a peak power number and they have too much lobe to start with.
I think Hot Rod or Car craft just did a test on an SBC where they did a simple change from a 224/224 114 to 110 or 108. Gained a lot of midrange, lost a little peak, but lost a lot of engine vaccum. The car went from 12" to about 6.5"
So what, call it evolution.
If a tuner would tell me that he would not tune a 9* overlap cam just because he is seing 107>109 LSA in the cam specs, I would pack my stuff in a hurry and leave. That would be the only indication I would need to prove to me he is a bad tuner and that I better spend my money with a "real" professional.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Operating on a theory, do you think the margin is going to grow as the cams get larger in duration ? For example we saw a 3 rwhp and 5 rwtq gain on the 228, can we speculate that a 236 might see 7 rwhp 9 rwtq ? Just guessing here.....Thanks again for all the data to look at.
I am actually leaning towards a different cam as of this time (el torro), but if I found a cam of similar size and powerband that makes more power, even if it be 3hp, I will get that one.
Id love to see a comparison of 224 cams with different lsa's all other things being equal and the same with the exhaust duration increasing. Say 224/224 224/228 and 224/232 for example.
Maybe in the future when you start doing head swaps on the engine dyno - you bring this thread back with the small and larger lift 224 or 228 cams and see how they take advantage of the better flowing heads?
i think it would be cool to see if you guys can come up with a very strong cam meant for a cam only motor.ive seen alot of people choose big cams and come up disappointed when they only make 400-ish cam only. my friend is one of those, has a 235/239 on a 112 and he came up with 396rwhp (forget the torque, think it was decent, but not great). then, on the other side of the coin, there are a lot of guys making 400-ish on smaller cams, high 220's, low 230's. it just makes me think that there would be a very good market for people going cam only if you guys ground a stout cam only cam. there seems to be a good amount of people going cam only, or stock 243's and such, so it might be worth a shot.
