LS1 block v.s. LS2 block
Here are my assumptions/insights:
LS2: Same blcok that the Escallade uses cast in aluminium along with LS6 heads and a LS-6 crank to keep it reliable in the upper RPMS. (these are guesses).
LS7: Here are where the big changes are. I have read that they are going with the dual cam in block setup with 3 valves per cylinder. This would most definately need a new block & heads. I have also heard that the engine will be high-reving, which suggests to me that they will go the all bore route and keep a similar stroke to the current LS6. All of this is strange to me though because this will most certainly make the LS7 priced significantly higher than the LS2, and pretty much throws parts-sharing between the platforms out the window. Maybe the LS2 will have the dual cam in block as well??? Who knows
Where did you dig up those pics? Any idea on what the "rail" rocker setup is made of? Seems like a LOT of valvetrain mass.
thank you for your time.
GM needs to finish up the electric valve stuff, if they want to be able to have a very efficient motor thats cheap and EASILY moddified for more power
WS6FirebirdTA00, I think the first C6 will ship around Nov. 2004, so its still a ways off. Hopefully some more official LS2/LS7 news and specs will come out this spring.
I don't have any idea what those components are made of, but I can find out if it's of interest.
The 1/2 pushrod JoSeY mentions was the first thing that caught my eye too. My minds eye just pictured a scene with a conversation similar to "Well if we was to put another tab-hang-thing on that shaft-twisty and then run some 9/32nd's solid-core double-taper moly-sumpthin, we could span across to that other-side sub-rocker deal-ie.. 'sides it'd look real Yurripean too!"
I'm pretty sure I won't be buying the first year...
Intake looks taller and with TB angled off to the pass side.
http://media.gm.com/division/2004_pr...OHV_3valve.pdf
http://patft.uspto.gov/netacgi/nph-P...S=PN/6,505,589
http://www.uspto.gov/web/patents/pat...-20030114.html
http://patft.uspto.gov/netacgi/nph-P...S=PN/6,505,591
Dope
Also, stating that something "looks heavy" or "too complex" is a bit of a rush to judgement. If the LS1 is the most advanced pushrod engine there is, you can bet that its replacement will really shock the OHC world.
