what kind of texas speed cam ???
Old Aug 9, 2009 | 01:06 PM
tornado-485's Avatar
Question what kind of texas speed cam ???
HI....
I need some help for choice cam for my car
but the prablem i need max power of HP
i wont 400-450 hp
so, what kind of texas speed i need???
my car mode:
comaro z28 A4 346ci stock bottom
patriot stage 2 CNC 243 59cc
FAST 92 and 92 TB
SLP pulley
373 rear gear
thermostat 160
slp oil pump
cam 2?? 2?? so what cam i should takes???
Old Aug 9, 2009 | 06:28 PM
MelScrilla's Avatar
depends on what you are doing with the car, are you daily driving, weekend warrior, hardcore racer.
The MS4 would probably get the most hp but it might not be good for daily, a 228 would be good to drive and be a real good performer but the top end power wouldn't be as good. With 59cc heads you also have to be careful about piston to valve clearance.
Old Aug 9, 2009 | 06:40 PM
ZMONSTER!'s Avatar
Why limit yourself to TSP grinds? If say look around and get some custom cam specs. Are your heads the old or new patriot 243? Are they welded to 59cc or milled?
Old Aug 9, 2009 | 07:23 PM
teke184's Avatar
and 400-450hp is a HUGE range for a goal.
with those heads...there are a dozen cams that could make 400-425hp....but to get above that you're down to a smaller list, particularly with the heads limiting cam lift.
the FAST will help though
more info on the heads needed
Old Aug 10, 2009 | 07:22 AM
thanks of all
i used the cas as weekend warrior .
piston to valve clearance -that is my point-
i dont no what size of lifte of cam shoud i use with out cut the piston 59cc make me thinks much . i dont know which is better MS3 ,Torquer 2,Torquer v3 or 233/239, cam which one of them will works better with this combo
the car made 340 rwhp 355rwtq sae
heads and fast 92
Old Aug 10, 2009 | 08:30 AM
TransAmcoupe98's Avatar
Of the cams you listed, the safest one of them would be the Torquer V.2. The lift is not nearly has high as the V.3 but it does have a slightly higher duration. Also, what kind of head gasket are you using?
Old Aug 10, 2009 | 08:33 AM
Damian's Avatar
LSX Mechanic
For an automatic car I would do something in the 228 range on a 114. Their 228R/114LSA cam is actually a great street cam, good manners, and makes good power. With a lot of compression, FAST intake, other supporting bolt ons and good tuning that cam will make 430-440 and still drive very similar to stock.
Don't put a big *** cam in your A4 and make it annoying to drive.
Old Aug 10, 2009 | 09:34 AM
LS1-NAVY's Avatar
u will also need a stall
Old Aug 10, 2009 | 10:23 AM
PREDATOR-Z's Avatar
Those heads being 59cc, I would have to agree with Damian, 228/228 on 114 LSA should fit with respectable PTV clearance. (unless you want to yank the heads and flycut of course)
It will have high cylinder pressures and good output throughout the power range.
so 228R on a 114 takes my vote.
Old Aug 10, 2009 | 11:13 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We have a new 228 lobe that would work very well for you. I also have a small split version we'll finish up this week. If you want the 228 single pattern I can sell you one of my dyno test ones at a discount!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Aug 10, 2009 | 02:45 PM
thanks every one
i will go with 228 cam
and i will see how mach power i will have
then i will poste my dyno number and sheet
thanks texas speed guys nice work.
