MS4 cam pushrods?
Old Aug 12, 2009 | 01:18 AM
franksaltz28's Avatar
Default MS4 cam pushrods?
I bought a set of ls6 heads and a ms4 cam used. they came with patriot gold double springs and what he said to be hardend pushrods. I got the pushrods and put them next to the stock ls1s. They look like they are identical. They dont have any markings on them, and they are the same length. Is there any way to tell the diffrence or are they stockers. If so what pushrods should i get.
Old Aug 12, 2009 | 07:27 AM
tripblackls1's Avatar
your using ls7 lifters right??
you need to measure because ls7 lifters cup sits .060 higher then stock ls1
Old Aug 12, 2009 | 09:16 AM
Yea im buying ls7 lifters for when the ms4 goes in. would that make me need a diffrent pushrod?
Old Aug 12, 2009 | 09:39 AM
Damian's Avatar
LSX Mechanic
More than likely you will need a slightly shorter pushrod with the LS7 lifters. I've found that 7.4's almost never work w/ the LS7 lifter to achieve proper preload. It's been in the 7.3-7.375 range.
Old Aug 12, 2009 | 10:38 AM
Jon@Texas-Speed's Avatar
With the MS4 we typically sell 7.425" on cam only setups. With the LS7 lifters, I would look into a 7.375". It is definitely a good idea to measure to ensure the correct preload is found. Let us know if we can help with anything else!
Old Aug 12, 2009 | 03:35 PM
PONTIAC SLP's Avatar
i'm running 7.400 with my ms4 and ls1 lifters.
Old Aug 13, 2009 | 12:15 AM
you dont have any problems with the ls1 lifters?
Old Aug 15, 2009 | 12:16 AM
So what would be the best lifter/pushrod combination for my build. I have two sets of ls1 lifters and pushrods. But i was going to buy better lifters, and pushrods for the application. Whats your oppinion.
Old Aug 15, 2009 | 12:30 PM
no everything works as well
Old Aug 15, 2009 | 02:13 PM
cool. Ive herd from more than one person that the ls1 lifters arent enough.
Old Aug 15, 2009 | 02:33 PM
USArmyZ28's Avatar
LS1 lifter on a cam similar to an MS4 here no problems. My hardened pushrods looked identical to my old ones.
Old Aug 16, 2009 | 02:34 AM
so what do you think i should do. Use the ls1 lifters with hardend push rods, or get better stuff. I also have ls2 timing chain that i could use, or i can buy an double roller timing chain. The motor is going to go through hell after the swap. I already drop the clutch at 6k at the track, and im thinking of spraying the car. should i put in the parts i already have or buy better stuff.
Old Aug 18, 2009 | 11:25 AM
bump....
