6.0L FI Build
Old Aug 12, 2009 | 09:58 AM
Bucktooth's Avatar
Default 6.0L FI Build
Engine Build Plans:
-Lq4 Running Used Engine
-New cam, oil pump, chain etc..
-Maybe katech rod bolts (not sure on that yet)
-Stock/slightly ported lq9 heads
-Reuse ls6 intake and 1-3/4" headers
-Underdrive pulley, largest procharger pulley, used F-1C w/intercoooler setup
-Use truck coil packs
-E-85
What head gaskets do you guys recommend for this setup?
Opinions on builds or recommendations?
Think i will use head studs as well.
I am guessing 550-575rwhp with roughly 9-11lbs boost that it will probably produce.
