whats a big or mid cam
Old Aug 12, 2009 | 03:41 PM
speeedo's Avatar
Default whats a big or mid cam
what consider a big cam or mid range cam whats the number evry one should look at ist lift or duration
Old Aug 12, 2009 | 03:50 PM
TooLateVTEC's Avatar
I consider big, a 239* and larger duration cam.
Most aftermarket cams are in the .600 lift range, even the 224's are almost .600 lift. So I consider the long duration cams "large".
Old Aug 12, 2009 | 03:58 PM
AznMuscle's Avatar
Yea, mid sized cams are 228/228 up to 239/239 IMO. I run a "large" by some peoples ideas, in a 242/248. Though I really think large are the 252/260 type guys with strokers and/or solid rollers.
Old Aug 12, 2009 | 05:33 PM
6th gear's Avatar
268/271 .675/.680 110lsa...thats a BIG cam
Old Aug 12, 2009 | 06:22 PM
PREDATOR-Z's Avatar
Something like that is what I call big
Old Aug 12, 2009 | 07:32 PM
SOMbitch's Avatar
LOL So what does that go in.....? A big CAT D12 Dozer or something......
Old Aug 12, 2009 | 07:58 PM
wickedbluess's Avatar
the torquer v.2. Is a decent size cam 232/234 595 598 lift at 112
Old Aug 12, 2009 | 07:59 PM
tillery's Avatar
240+ duration at .050 is big, with the latest spring technology and ramps rates large lifts are attainable with LS engines. BTW-that looks like a cam outa one of my pump engines.
Old Aug 12, 2009 | 08:07 PM
30th t/a's Avatar
220 duration = small
230 duration = medium
240+ duration = big
and thats in a 346 cid.
Old Aug 14, 2009 | 08:03 PM
3timeracin's Avatar
Alot depends on the engine size I had a 632 with a 266/276 .712 112 and it idled smooth and I have also had a 441 lsx with a 252/266 .656 112 that was pretty mellow too, but if you put that in a 346 it would be rough as hell
Old Aug 15, 2009 | 05:56 PM
camaropilot's Avatar
The biggest dozer Cat makes is a D11, and thats bigger than the cam in a D11
Old Aug 15, 2009 | 07:05 PM
ttranssam's Avatar
ive got a 240 cam and it idols nice and so far everybody says this cam is very driveable...
Old Aug 15, 2009 | 07:18 PM
transamfreak01's Avatar
i think it comes down to the person honestly. i have a 226 in mine and i think its too small now. this winter i will be going with a 230+ with some heads. the only way you will be able to say for urself if it is too big or not is to drive in a car with the cam. listening to what everyone says will not help you
Old Aug 16, 2009 | 01:04 PM
JPH's Avatar
JPH
That looks like a crank mark? LOL
Old Aug 16, 2009 | 01:05 PM
JPH's Avatar
JPH
240+ duration = big
Perfect example imo.
Old Aug 16, 2009 | 03:53 PM
PREDATOR-Z's Avatar
It is, But i was referring to size
Old Aug 16, 2009 | 09:34 PM
hammertime's Avatar
Sorry for the but I couldn't resist
240+ duration = big
JPH is right, perfect.
Old Aug 17, 2009 | 12:01 AM
PREDATOR-Z's Avatar
10 cylinder ship crank., yeah that is big, immagine the cam, I wonder what would be the specs?
Old Aug 17, 2009 | 12:07 AM
KillaCamZ28's Avatar
240+ duration = big
I second that,
Old Aug 17, 2009 | 01:01 AM
phoenix1987's Avatar
Considering it needs torque and good usable power, I bet its a reverse split.
