forged 347.. how strong is it?
Old Aug 15, 2009 | 10:28 AM
johnLs1camaro's Avatar
any ideas on what type of piston I should do, Because Im looking at doing a higher compression motor, but still run pump gas. Ill be running a few gallons of race gas on the hit though.
Old Aug 17, 2009 | 11:05 AM
white01ss's Avatar
My engine builder uses Diamond pistons in everything he builds.
Old Aug 17, 2009 | 06:33 PM
HitmanLS1's Avatar
im thinking about a 347 build to. But u kno the stock bottom end is good for a 200shot.
Old Aug 17, 2009 | 10:20 PM
^yeah, but nitrous is addicting. I want a motor that can handle a bunch of 200+shots.
Old Aug 17, 2009 | 11:28 PM
Gregorya24's Avatar
im building a 347 as we speak hopefully have it done by this weekend my set up
stock ls1 block
stock ls1 crank
ls7 lifters
ls6 ported oil pump
-4cc valve relief 3.908 bore mahle pistons power pak
scat h-beam rods
Advanced Induction custom grind camshaft
Advanced Induction ported 241 heads 59cc
Fast 90 setup
150 to 200 shot on a 11.5.1 compression ratio
Old Aug 17, 2009 | 11:37 PM
Prerun4fun13's Avatar
very strong
Old Aug 18, 2009 | 12:18 AM
awesome build, just wondering if you did any work to the block? did you get it lined or honed?
edit- my bad i see where you said 347 now.
I was looking at going with -4cc valve relief 3.905 bore mahle pistons.
Old Aug 18, 2009 | 12:56 AM
Lawnboy's Avatar
Restricted User
2001 LS6 M-6 SS CAMARO
MOTOR:
Built by Merkel Racing
Balanced/blue printed
LS6 block
Diamond Blower Pistons
Diamond Pro-Select Piston Rings
Heavy - Duty wrist pins
Eagle 3-D ESP H-beam rods
Callies DragonSlayer Crankshaft
DM Performance Main Girdle
SLP Double Roller timming chain
SLP High Volume oil pump
ARP main stud kit
King bearings
HEADS:
Absolute Speed Hand Ported
Ferrea Pro Flow Radius Competition Valves
2.00" Intakes 1.57" Exhaust
TSP dual Valve springs
Titanium retainers
Rocker Arms/Valvetrain
LS1/LS6 Harland sharp upgrade
Compcams High tech push rods
GM LS7 Lifters
Camshaft:
Thunder Racing Custome Blower Cam
215/231 .601/.574 116 LSA.
Intake/PCV
LS6 intake manifold
Accufab throttle body
ZO6 Mass air sensor
LS6 Valley cover
LS1 AMW catch can
LS1 Breather catch can
(vents both valve covers)
Fuel System:
Racetronix LS1 Intank DoublePumper
#60 Flow Matched Injectors
Speed Inc custome fuel rails
Fuel = Pump gas/Methanol injection
Tuning = Vette Doctors
Procharger System:
LS1 High output kit with 8 rib upgrade
D1-sc with 4.5" High Flow Twin intercoolers
ATI super damper
Old Aug 18, 2009 | 09:58 AM
Shinobi'sZ's Avatar
Originally Posted by Jason 98 TA
I've made over 850rwhp on my TSP 347cid short-block without any problems. We offer compete rotating assemblies, if you decide to build one give us a call! I bet we can help put together a nice combo for you!!!
ditto...still using the stock crank too.
Old Aug 19, 2009 | 02:09 AM
transamfreak01's Avatar
yeah i wouldnt even bother with changing the crank...
but yeah a built 347 will take nitrous like a ****. are you planning on running a two stage set up or just a 200 shot out of the hole?
Old Aug 19, 2009 | 02:14 AM
pending on money when the motor is finished. Im either going to do a 150 plate, with a 50 to 100 nozzle. If I have enough money when the motor is finished, I am going to do a DP kit.
Old Aug 19, 2009 | 03:27 AM
  #32
99Ls1fever's Avatar
Awesome Builds Guys!!!
Old Aug 19, 2009 | 12:12 PM
  #33
Shinobi'sZ's Avatar
Sorry should have went into more detail. I have a TT setup that makes 850 rwhp on the high boost setting...but for normal every day use I don't use the boost controller and with just the 8.75 lbs wastegate springs make approximately 600 rwhp. The tune is setup for the 18# boost setting so the low boost setting isn't really even optimized.
Old Aug 19, 2009 | 01:05 PM
  #34
99Ls1fever's Avatar
I wouldnt switch the stock crank out on any of these engines. I and about 10 people we have built engine for and with are all high 8xx hp vehicles and are all running stock cranks.
Old Aug 19, 2009 | 06:02 PM
  #35
yeah i think its a waste of money. if you want it for piece of mind knowing its completely forged go ahead but if it were me id spend the good chunk of money elsewhere
Old Aug 19, 2009 | 08:45 PM
  #36
99Ls1fever's Avatar
The money you save you could put into cylinder heads like I did. PRC Heads.
Old Aug 19, 2009 | 10:53 PM
  #37
question, can i get a 98 block to a 347?
Old Aug 19, 2009 | 11:55 PM
  #38
99Ls1fever's Avatar
Yes!
Old Aug 20, 2009 | 12:12 AM
  #39
Lawnboy's Avatar
Restricted User
callies 3.625 dragon slayer here, for the price i got it for i couldnt pass it up , and worth the extra insurance
Old Aug 20, 2009 | 12:43 AM
  #40
Originally Posted by 99Ls1fever
Yes!
thanks, cuz thats what I bought.
