forged 347.. how strong is it?
Old Aug 13, 2009 | 10:56 PM
johnLs1camaro's Avatar
Default forged 347.. how strong is it?
I found a good deal on a stock ls1 block. I am wanting to build a engine right now and Im kind of thinking about doing a 347, I am going to do a good set of rings, rods and pistons in it. The car will be on a 200 shot also. Just wondering what type of power you guys are making on this setup. Also what is the max power you think my block could handle? I figure on running a decent cam, it will be 24x's durations and stage 2.5 5.3 heads.
Should I not do this and look at going more towards a lq9 or 4?
thanks for any input guys...
Old Aug 13, 2009 | 11:31 PM
fortmyerspolice's Avatar
I've seen a lot of guys go upwards of 700+ HP with turbo setups.
Old Aug 13, 2009 | 11:35 PM
Lawnboy's Avatar
Restricted User
I just built a forged LS6 (newer block) uses the shorter LS2 head studes.
Going to make 650-700 RWHP with procharger
Old Aug 14, 2009 | 01:02 AM
jmill96Z's Avatar
Sounds alot like my setup. I didn't have any dyno numbers, but it was running 10.0's nosing over around the 1000' with the LS6 intake.
Old Aug 14, 2009 | 01:25 AM
Im really wanting to run low 10's on the car...
Also, am I stupid to do this on a 98 block, I know they dont have as much meat on them, but i figured I could atleast get it to a 347 right? If not theres another block I can purchase, its just the 98 was pretty cheap.
Old Aug 14, 2009 | 02:58 AM
transamfreak01's Avatar
are you wanting to run low 10s on motor or spray?
Old Aug 14, 2009 | 03:02 AM
spray...
Old Aug 14, 2009 | 03:09 AM
i would do a set of trickflows and a custom grind cam. are you keeping it full weight?
Old Aug 14, 2009 | 08:04 AM
digitalsolo's Avatar
I plan on making ~750 RWHP from my setup.
1998 LS1 Block
Stock Crank
Callies Compstar Rods
Wiseco 2618 coated pistons
ARP hardware (studs whever applicable)
Clevite 77 H Series Bearings w/ Durabond Cam Bearings
Stage III Heads
Boost
You should certainly be able to make 10 second power out of a forged 347, just make sure you have a good controller for that nitrous and you should be fine.
Old Aug 14, 2009 | 10:49 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
I've made over 850rwhp on my TSP 347cid short-block without any problems. We offer compete rotating assemblies, if you decide to build one give us a call! I bet we can help put together a nice combo for you!!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Aug 14, 2009 | 11:18 AM
Thanks for the help guys. I have a decent controller right now, so im not too worried about that. Also my car is going on a diet, Ive already lost a few things on it now.
I like what everyone is telling me, from the looks I think the forged 347 will work great for me. also jason ill give you a call, and see what you got.
Old Aug 14, 2009 | 11:39 AM
conan's Avatar
I made 580 rwhp when I lived at sea level on my forged 347 from TSP. Now I'm at 520 rwhp at 5,600 feet elevation, on 11 #'s of boost. This winter I'm going to a smaller pully and some meth to brake the 600rwhp mark. The bottom end doesn't worry me one bit. A 200 shot won't be a problem... Hit it with a 300 shot
Old Aug 14, 2009 | 11:55 AM
^ yeah im pretty sure ill go with more juice..
Old Aug 14, 2009 | 12:29 PM
white01ss's Avatar
I'm going with a LQ9. You have to ask yourself, why did GM put this block into their 3/4 ton trucks and Esquilades? Durability. It's cheap, strong, and good to 1000 rwhp.
Old Aug 14, 2009 | 12:40 PM
Yeah, that was my original plan, but I can get bare ls1 blocks and crank for pretty damn cheap also. I save the weight also. Yes I do agree, rhe blocks are strong though.
Old Aug 14, 2009 | 02:23 PM
99Ls1fever's Avatar
I am at 880 with a dual stage and the bitch flat out runs!!! Never have had any issues!
Old Aug 14, 2009 | 03:00 PM
Hell yeah, thats what I want to here!
any good ideas on type of piston,rods, and rings I should go with? like said im looking at a 24x's duration cam, lower 6xx's lift. a good amount of nitrous...
Old Aug 14, 2009 | 05:03 PM
fatmat80's Avatar
i would go callies everything..everyone i have spoken with recomends them!!!
Old Aug 14, 2009 | 06:02 PM
black00ssFL's Avatar
Actually, I'm gonna go with it is cheaper for Iron and since it isn't a performance vehicle and a truck....the extra weight is not an issue.
Old Aug 14, 2009 | 11:25 PM
99Ls1fever's Avatar
Compstar Rods, Diamond Forged Pistons 9.5 to 1, Mahle Piston Rings. 3 of us out of the AIR Shop are right around mid to high 800's. All blower Nitrous apllications. 1-YSI, 2- G Trims Vortech Superchargers.
