Noisy Valvetrain?
Old Nov 23, 2003 | 03:38 PM
NO CATZZ's Avatar
Question Noisy Valvetrain?
I just finished my Forged 346 project and my valvetrain is a little noisy. Here is my setup:
Absolute Stage II heads(cut .030 by Jay)
Stock rockers
7.35 pushrods
Comp 224/228 Cam
Comp 'R' lifters
I have heat cycled the motor about 5 times then retorqed EVERYTHING. When I installed the rockers I took them to 0 lash by hand and then it took a tad more than 1/2 turn to get them to 22ft/lbs. I thought this would be perfect but to me it is a little noisy...but I have no knock retard(-0.1 max) so I guess that is a plus.
Should I go with a longer pushrod and then shim the rocker pedestal to lessen the noise?
Thanks
Josh
Old Nov 23, 2003 | 03:55 PM
Larry's Avatar
Most of the aftermarket cams have a smaller base circle than stock. Unless your heads are milled you probably need a 7.40 long set of push rods.
Shims under the rockers is going the wrong direction for more lifter preload. That makes for less preload.
Old Nov 23, 2003 | 04:32 PM
NO CATZZ's Avatar
I mentioned the shimming because I think 7.4 pushrods my be a tad too long...I will see if I can scrounge up a set and try them out. Thanks.
Old Nov 23, 2003 | 05:39 PM
DaleMX's Avatar
From what I understand, Comp-r lifters need like 0.0 to .010 lash max.
