cam break in
Old Aug 17, 2009 | 09:25 AM
Bluvette28's Avatar
Default cam break in
I have a 2000 auto camaro and I am in the process of installing a mild cam. I heard I have to drive it 500 miles to break it in befor a dynotune. Is this true??
Old Aug 17, 2009 | 10:33 AM
WSsick's Avatar
500 is what ive heard, although some go straight to the dyno. some drive it around for a while, and do the final miles on the dyno.
Old Aug 17, 2009 | 10:37 AM
LS1Formulation's Avatar
Uh... no. It's a freakin' roller cam, there's nothing to "break in". This isn't a flat tappet cam that needs to establish a wear pattern. Install it and go to the dyno. Won't hurt a thing.
Old Aug 17, 2009 | 01:35 PM
Bluvette28's Avatar
Yea I didn't think it had to be broken in but people tell me I'm stupid if I don't. What about gears do those have to be broken in??
Old Aug 17, 2009 | 01:40 PM
Rear end gears should be broken in... drive 30 miles, shut it off, let it cool completely, repeat 3 times. Then take it easy for a few hundred miles and then you should be good to go.
Old Aug 17, 2009 | 01:58 PM
Damian's Avatar
LSX Mechanic
I recommend 2 heat cycles on the springs, meaning you drive the car till operating temps, then shut it down. Repeat twice.
Change oil.
Beat the **** out of it.
