New motor. Bad cranking compression
One cylinder is at 220. Adjacent cylinder is at 120!! 5 of 8 have abnormal psi. Leakdown showed an 80% loss.
Everything looks brand new. Rings look good. Cylinders look good. Heads/valves are fine. Next thing to check i guess is cylinder distortion.
Any ideas?
Any ideas?
If the rings and valves are ok, then it has to be a head gasket. if your cylinders are distorted, then your rings will leak. You can't do a leak down on a engine unless it has been run to break in the rings. Did you do your compression check with the throttle wide open? This will cause abnormal psi if you don't.
Were the cylinders honed by machining or hand held drill? What is the ring end gap? Cylinders could be out of round. If it was the head gaskets I believe you would have 0 pressure in the effected cylinders.
