What do I need to buy with a cam
Old Nov 24, 2003 | 08:13 AM
99-LS1-SS's Avatar
STF Veteran
Default What do I need to buy with a cam
I want to buy a cam and I don't know what else I will need to buy(like push rods or anything like that). Can ya'll help me out? What is the best cam? I am looking at a TSP Custom 224 Cam: 224/224, .566"/.566", 114 LSA.
Old Nov 24, 2003 | 09:32 AM
Noyzee's Avatar
8 second mod
You will need Valve springs, pushrods wont hurt, and LS1 Edit tuning would be the best. While your in there you mine as well do a timing chain as well. depending on milage a oil pump wouldnt hurt. Good luck.
Old Nov 24, 2003 | 03:16 PM
jrp's Avatar
jrp
SN95 Director
with that cam (im thinking of getting it myself ) you can run a single spring fine, i'd recommend the manley kit from SDPC, comes with springs and tit. retainers for 178. i'd upgrade your pushrods but its not an absolute neccessity.
Old Nov 24, 2003 | 04:56 PM
Krab's Avatar
Get some springs, titanium retainers, a new oil pump, and a timing chain. You don't absolutely need new pushrods, as long as the stock ones are straight. You'll also need tuning after it's all in. jrp, is that cam too big for your liking? Why do you want to go to a smaller cam?
Old Nov 24, 2003 | 05:04 PM
jmX's Avatar
jmX
This should answer most of your questions...
http://www.ls1howto.com/index.php?article=23
Old Nov 24, 2003 | 06:25 PM
Jabroni's Avatar
I think you've picked a good cam spec with a comfortable lift. It isn't always about lifting to the Stratosphere to get good power. I'd get some hardened pushrods, titanium retainers and maybe a new timing chain, too. Especially in a 99 car. You can use the Comp 918 springs if you like but some folks may say use a dual. With that lift the 918's should be fine.
Old Nov 25, 2003 | 12:06 AM
jrp's Avatar
jrp
SN95 Director
i dont want to keep swaping for emissions time, plus going down to a 224 wont loose me much power.
Old Nov 25, 2003 | 12:16 AM
FILE's Avatar
Gaskets will be nice too.
Old Nov 25, 2003 | 12:04 PM
99-LS1-SS's Avatar
STF Veteran
Thanks for the article
