Big Cube Sleeper potential???
Old Aug 21, 2009 | 01:42 PM
chevca's Avatar
Default Big Cube Sleeper potential???
First off I have been out of this for awhile, I used to follow this stuff pretty closely but haven't for awhile and therefore am a little out of date.
Anyways what I am thinking about or wondering about is how much power could I make with a big cube engine like 454 while still retaining a smooth idle. Sort of the ultimate sleeper, something I could fit in my 02 Camaro SS without any tell tales that I did anything. Like I am even thinking of keeping my stock SLP exhaust.
Your thoughts and ideas?
Old Aug 21, 2009 | 02:13 PM
2002 SS's Avatar
gonna be tough... im not sure you can have to much of a sleeper with big cubes without sacrificing power.
Old Aug 21, 2009 | 03:41 PM
Ericbigmac83's Avatar
Save yourself 10k and buy a nitrous kit
Old Aug 21, 2009 | 03:45 PM
BigRich954RR's Avatar
I got a 427 that idles like stock but you can hear from the Exhaust that its camed
Its a smaller cam 232/242/ 650 lift and 115 lsa.
With cats and quiet muffles i think it would pass close to being stock. But not sure and to add all that stuff would kill power
Old Aug 21, 2009 | 06:00 PM
PREDATOR-Z's Avatar
Of course you can and it will make more trq than Hp. But most poeple once in big cube territory want it all out of it.
You can make a 500rwhp 454 as tame as a stock car, untill you mistakingly put your foot down
Old Aug 21, 2009 | 07:22 PM
5_02ls1's Avatar
here ya go....https://ls1tech.com/forums/new-produ...3499-99-a.html
top it off with a nice set of heads,have a custom cam spec'd fast92/92...some 1 7/8 headers.....should be easily done...but like predator said it can be tame till you hit that go pedal....
Old Aug 21, 2009 | 08:16 PM
Bader-X's Avatar
stock LS7 is tame and it`s 427 it can be done... just install dual cut-outs or a single cut-out for fun and more power when racing.
Old Aug 21, 2009 | 08:20 PM
Daryn's Avatar
Formerly darynC-10/23/10
just get a 408 and put a turbo on it.. sleeper at idle.. but OH MY GOOOOOODDDDDD when its on the wood...
Old Aug 22, 2009 | 12:41 AM
MelScrilla's Avatar
Vengeance did a 496 Warhawk block thats kind of a sleeper. Since all the standard deck LS blocks have the same dimensions the only give away would be the sound. I would run a pretty queit exhaust like a magnaflow catback with a cutout in the I pipe. Get a ported fast sanded down and powder coated flatblack like a stock gm intake, black headers to not attract any attention, stock valve covers, then you could pop the hood and no one would know any better.
A guy that doesn't know the LS stuff wouldn't know the difference between the sound anyway and if they got suspicious you could always say it was a 383.
Old Aug 22, 2009 | 04:15 PM
hotrodscrap's Avatar
+1, I like that idea, their WarHawks are crazy, good bit of money too though.
-SS
Old Aug 22, 2009 | 07:29 PM
transamfreak01's Avatar
-SS
yeah i wouldnt buy that unless i wanted an all out race car. heres an idea, run a 408 with a decent h/c/i set up and then run 2 kits on the car. make one kit visable and hide the other. if they find one i doubt they will look for the other one.
Old Aug 22, 2009 | 09:20 PM
SHovV's Avatar
thier build was with a tall deck. that had to space the k-member 1/2 inch lower to get the valve covers to clear
Old Aug 23, 2009 | 06:11 PM
chevca's Avatar
I like the warhawk block idea, but I thought I read somewhere that a re-sleeved LS2 block would work just as well as long as I don't use any power adders (ie blower,turbo, nos)? And I don't know what the cost comparison would be, I haven't found one online yet? I also looked at the LSX block and while I am sure the weight difference is negligible I don't know if I like replacing an aluminum block with a steel one.
As for the hp loss, I am not to worried about that, in fact what got me on this train of thought was doing a head cam swap for 500hp but I figured I could get near the same hp just smoother if I did a big disp. And while more the 500 is interesting I start to get worried about axle breakage, trans breakage and (I know I really have to go hog wild) car breakage like bending the chassis since I do have t-tops.
One thing I don't want is extra tubes inside the car, no matter what I do with the engine.
Old Aug 23, 2009 | 07:46 PM
davidws6's Avatar
Default Big cubes
If you do decide to go big, the SLP will be very Raspy ! I know, I had it on my 402 for a while. My resleeved LS2 block 454ci from Steve @ RED is pretty mild but with a 4 " Magnaflow, you know it's not stock.
Old Aug 24, 2009 | 01:44 AM
MelScrilla's Avatar
for 500 hp you could do a 383 with your current block, some nice heads and an aggressive cam. Or a 408 with some milled L92's and a custom cam. Either way you'll be at 500 or past it. Some people are even making around 500 with a stock cube LS2 with L92's.
