LS1 ARP head studs
Old Aug 23, 2009 | 03:28 AM
Turbov8's Avatar
Default LS1 ARP head studs
Hi all
I have an ls1 that i am building with a set of Dart Pro heads.The block is a brand new crate block. I am having problems with a set of head studs i got as they were the wrong ones.
What's wrong is that the threads in the block are different lengths from the top ones to the bottem ones.
Can someone please help me with getting the right length studs?
Thanks, Daniel
Old Aug 23, 2009 | 03:35 AM
jetlag's Avatar
I'm not sure if this affects you or not... but I'll be buying ARP head bolts for my car soon, and noticed that there is a different part number for 2004+ blocks.
So maybe you have the wrong part number?
Old Aug 23, 2009 | 03:42 AM
Turbov8's Avatar
Well i heard that there is 3 different head studs for LS1,s
Old Aug 23, 2009 | 08:34 AM
vettenuts's Avatar
There are at least two that I am aware of, and one has all the same length. What is the number on your kit? If you have a new crate block, it is likely the later design.
Old Aug 23, 2009 | 03:18 PM
quick346's Avatar
the older have the 2 shorter bolts on the very front and back top holes. the 2004 and newer are all the same lenght and are shorter than the longest one of the old stlye
Old Aug 23, 2009 | 04:13 PM
CroonerSS's Avatar
Also, there is stamp on the front of the block that gives the date. Look right on top of where the passenger cylinder head goes at the front of the block.
Mine says E274 which means May 27 2004 so I have the new style that uses all the same bolts.
Old Aug 24, 2009 | 08:23 AM
Turbov8's Avatar
I will measure up the depth of the holes and let you know.I realy need to get this sorted out.
Thanks Daniel
Old Aug 24, 2009 | 03:56 PM
Turbov8's Avatar
So i have checked all the hole depths in this new block and they are all the same length.
So what arp stud kit number is it for them?
Thanks Daniel
Old Aug 24, 2009 | 04:27 PM
PAGregSS's Avatar
My 6.0L block took all the same length studs, but mine are 1/2" studs.
