10 sec. heads and cam
Old Aug 24, 2009 | 07:06 PM
19trans_am98's Avatar
Default 10 sec. heads and cam
anybody have any thoughts on what i should go with...i've looked into tfs and maybe even an afr...what do you guys think about an all pro head? what would be the best head for a max effort 346 build...already have supporting short block just need to top it off with a set of heads and a cam....comp. will be about 12:5.1 with 64cc heads so that should bump the power up a lil....maybe i need to go solid roller? or stick with hyd.? will be running vic jr efi with 90mm tb...also what about cam custom or off the shelf...looking to get into the 10.5's on motor then ill be adding a lil spray and getting into the 9's..
Old Aug 24, 2009 | 07:10 PM
TransAmcoupe98's Avatar
Search Chrs1313. Pred-Z spec'd him out the El Torro cam. He runs 10's through an auto and stock gears.
Old Aug 24, 2009 | 07:16 PM
tripblackls1's Avatar
all pros are going to cost about double of afr or tfs and really are not going to do anything on a 346, i would say you need at least 427 ci to use all pro heads
Old Aug 24, 2009 | 07:41 PM
surely somebody here is running in the 10's with the tfs or afrs and a cam? if so would you care to tell me engine specs?
Old Aug 24, 2009 | 08:50 PM
nastychevelle's Avatar
http://lmgtfy.com/?q=10%27s+with+hea...am+in+a+camaro
Old Aug 24, 2009 | 08:59 PM
Johns00Z28's Avatar
Originally Posted by nastychevelle
^ lmao!
Old Aug 24, 2009 | 09:02 PM
726.0chevelle's Avatar
13 Second Truck Club
^^^^ thats cool lol how did you do that?
Old Aug 24, 2009 | 09:16 PM
Search "10 second daily drivers". That will give yo an idea.
 Michael S. Palmer
Old Aug 25, 2009 | 06:41 AM
www.lmgtfy.com
Old Aug 25, 2009 | 11:42 AM
ThunderStruk's Avatar
I would definitely look into the Trick Flow cylinder heads. As far as the camshaft goes, our new RapTR camshaft works really well with those particular heads.
Old Aug 25, 2009 | 12:57 PM
WSsick's Avatar
call a sponsor, or predator z or pat g. youre gonna wanna go custom for this. its gonna big, so imagine a big stall with it. you might want a gear too.
Old Aug 25, 2009 | 01:26 PM
WS6TransAm01's Avatar
CARTEK Racing
"max effort" should be faster than 10.5...
Im ran 10.3 with LS6 heads almost 2 years ago...
In my oppinion, the TFS is the head to go with. As far as cam choice goes, I would contact a sponsor or someone like PredetorZ for a spec.
