Untuned cam and long trip to tune
Guys/girls. Read this - From 1998-2000, we had absolutely NO TUNING for internal modifications, and raced all the time. Back then we drilled the TB hole, and for those who could afford it, put a MAFT on the car, and went to the dragstrip
Yes, tuning is necessary. Of course. Is it going to be the death of your engine if you drive it untuned with a cam or heads/cam? NO. We were rolling racing to 150mph with untuned heads/cam cars 10 years ago.
Of course this excludes turbo/supercharger/nitrous cars.
/rant.
/rant.
/rant.
/rant.
I bet they ran like **** too.
/rant.
The reason for this is your car will adjust the fueling itself with STFT and LTFT under this RPM (why do you think we have those fancy O2 sensors?). After 4k you start relying on MAF and calculations that are wrong for your setup with no fuel trimming taking place, this CAN hurt your motor.
Is it going to idle bad, surge, and make lower power? YES.
Is it going to destroy your motor to cruise to your tuner on the highway? NO.
Your not going to wash down **** unless you put in bigger injectors.
Listen people, since reading comprehension must be on shortage today I'll spell it out. I never said "Hey you should always drive your car untuned". I was putting it into perspective, because people act like it's going to be catastrophic to your engine to drive it untuned for a while. In an N/A setup, especially a cam only or heads/cam car, this is silly nonsense. You can drive a car untuned, and it is not going to hurt anything as long as you aren't a moron and redlining at every red light. Should everybody do this? No. Should it be done at all? No. But if somebody is in a pinch or needs to drive elsewhere to get the car tuned, it isn't going to throw a rod through the hood like the internet mechanics will have you think. You're not committing murder to your engine driving it untuned for a few miles.
-Joel
A big duration cam (mid 23x+) is a higher risk untuned for 2 reasons (1> It will be pig rich at idle and that could wash you cylinders), (2> It will be lean above 4K rpm and that could cause detonnation and kill your pistons)
Now for that smallish 226, it should be fine to reach that tuner. Things to avoid (staying at idle for too long a time (severe back to back traffic), going above 4K rpm or Wide open throttle to avoid lean condition)
Highway cruise speed will be best.
A big duration cam (mid 23x+) is a higher risk untune for 2 reasons (1> It will be pig rich at idle and that could wash you cylinders), (2> It will be lean above 4K rpm and that could cause detonnation and kill your pistons)
outstanding advice.
