biggest street strip cam
Old Aug 27, 2009 | 11:46 PM
streetassasin's Avatar
^lol Didnt your old car have a ms4?
Old Aug 27, 2009 | 11:57 PM
lemons12's Avatar
Yes I did, my cam matched my setup better though...
410s
4k VIG (more like a 4500)
free flowing exhaust
ported heads
ported 9090 setup
Blah, blah, blah.... Just saying he should open his options up a bit more.
Old Aug 28, 2009 | 12:10 AM
WSsick's Avatar
Originally Posted by kinglt-1
Just get a custom grind! Anybody that ever posts a thread "whats the biggest dd cam" never gets a straight forward answer. It's kind of hard to give an accurate answer because peoples perceptions of what is a daily driver cam varies like the the weather!!
there ya go. thats the only thing you need to know. custom grind all the way. good setup > giant cam, every time. look at the link lmeons posted, perfect example. and i agree with whoever said go ride around with people from your local clubs. itll give you an idea of whats streetable to YOU. for my friend, his low 230 is fine, for me, ive driven an ms4 in an m6 and i thought it was fine. it all depends on what YOU consider streetable.
Old Aug 28, 2009 | 12:19 AM
racecar's Avatar
I have a TSP 233/239 .598/.603 in a LS3
I would not call it streetable, it is real strong from 4000-6500, but can be tough to get moving from a stop sign, or cruising around town.
I would go 224 intake duration for anything that is 90% street. LS motors run great with small cams, if you have good heads.
Old Aug 28, 2009 | 12:55 AM
DSkyles's Avatar
^adding to that, smaller cams make a more broad range of power. Big cams tend to have a higher powerband, which is not good if you don't plan on wrapping the motor too high (which is not recommended on a stock motor). You probably want something that makes good power across the board.
Old Aug 28, 2009 | 02:11 AM
02sslayer's Avatar
Originally Posted by lemons12
Why are you stuck on getting a bigger cam?
Why not get a cam that matches what your setup will consist of and will be intended for?
im just tryin to make the most N/A Hp i can. i mean i dont want the biggest, there are larger cams than ms3. and i dont drive my car year around. i mean why not get a big cam ive heard that the ms3 is a great cam. but honestly idk, i change my mind alot on what mods im gonna do
Old Aug 28, 2009 | 02:14 AM
02sslayer's Avatar
and also i plan on doing a 383 this winter or bigger and im gonna get the fast 92/92. but i guess there are alot of options including a custom grind, ill figure it out one day
Old Aug 28, 2009 | 02:16 AM
lemons12's Avatar
HP doesnt mean anything...
My car dynod 320rwhp.. I raced a car the other day that made 425rwhp.. I put 2-2 1/2 lengths on him from 35-125mph..
HP DOESNT MEAN ANYTHING!!!!
A properly matched setup will ALWAYS beat a setup that was just thrown together.. you do NOT need a big cam to be fast and the small cams CAN and DO beat bigger cam'd cars.
look at the link i provided on page 1..
Old Aug 28, 2009 | 12:47 PM
SS4Luck's Avatar
I dd my MS4 and if the car didnt shake because of the solid motor mounts i never would notice it wasnt the stock cam. My tuner is amazing though
Old Aug 28, 2009 | 12:52 PM
heres another option, predatorZ speced me this cam: 230/234 .612 .598 111+3 xfi/xer for a DD on nitrous
Old Aug 28, 2009 | 01:06 PM
Daryn's Avatar
Formerly darynC-10/23/10
just run a t-rex -ms4- thunders StRoKeR cams or texas giant's ... if that the answers u lookin for ?those big cams only make 10ish more hp over the "middle" cam and cost alot more to get supporting mods... IE injectors... intake, heads... cause those big cams need air flow..... if not.. u have a polished up nice sounding turd that only does 12's
Old Aug 28, 2009 | 01:13 PM
  #32
lemons12's Avatar
I have a buddy with a 6.0l in his z28.. ms4/full exhaust...
runs 8.4s@84mph...
the girlfriends car has ls6 intake/ls6 cam/full exhaust/373s.. she runs 8.3s-8.4s@84mph..
one sounds mean as **** and one sounds bone stock... they both surprise people with their cars... for different reasons though..
Old Aug 28, 2009 | 03:54 PM
  #33
david vericker's Avatar
Make sure you get a custom grid that is suitable for your set up. I had Futral Motorsports spec out my cam based on the intended application. The engine runs great NA (low to high rpm's...no dog down low) and it just loves the juice. I consider the car to be very streetable,but it's not something your mother would probably enjoy riding in.
Old Aug 28, 2009 | 05:17 PM
  #34
2000SS1979's Avatar
runs 8.4s@84mph...
I have a huge cam also.. Sounds awesome but my old custom PatG 224/230 was for sure faster.
On the other hand though. I think they are both streetable just like a small cam. Never had a single problem I think it is all in the tune.
Old Aug 28, 2009 | 05:18 PM
  #35
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Checkout all my engine dyno camshaft threads. You can use that data to select a camshaft that makes power in the rpm your wanting to be in! We have tons of options, give us a call so we can discuss your options & goals. I also have tons of dyno test only camshafts you can buy at a pretty nice discount!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Aug 28, 2009 | 05:29 PM
  #36
lemons12's Avatar
Well my Ms4 was DEFINITELY faster.. and a LOT more potential.. But this cam gets its done and can definitely be as fast as some other not so well setup big cam cars..
My ms4 tune is better than my 226 tune..
Old Aug 28, 2009 | 05:35 PM
  #37
SSdimension's Avatar
G5x4 cam4sale. .6xx/.6xx. Although NOBODY know what the specs are they say it almost identical to the t rex cam. .609/.612. Should be around there somewhere....
Old Aug 29, 2009 | 11:46 PM
  #38
VaderZ's Avatar
I say don't get anything bigger than a 230/230 cam for DD.
Old Aug 30, 2009 | 03:44 PM
  #39
LSXFORMULA99's Avatar
i have a 224 in my car now, if i could do it over i would have something bigger.
By Brett Foote | 2026-06-04 05:00:17
