ARP Head Stud Torque Specs???
Old Aug 30, 2009 | 01:55 PM
99LSS1's Avatar
Default ARP Head Stud Torque Specs???
Can't seam to find Torque Specs for the ARP head studs??? Need #s for bolt to block as well as #s for the nuts to bolt. Thanks
Old Aug 30, 2009 | 02:13 PM
Daryn's Avatar
Formerly darynC-10/23/10
the STUDS should not be tightened in the block, only till they hit bottom , as for TTY specs. ive always did 3 rounds. 25-50-80 . some may do it different, that how ive done it
Old Aug 30, 2009 | 02:59 PM
99blancoSS's Avatar
hand tighten studs in block nuts are 70 ft lbs, dont forget the molylube. (you guys should know that already )
Old Aug 30, 2009 | 05:10 PM
99LSS1's Avatar
Thanks guys... The moly lube is a must!!!!!
Old Aug 30, 2009 | 07:05 PM
vettenuts's Avatar
According to ARP, the 70 lb-ft final was changed to 80 lb-ft with their lube. When I last spoke to them, they indicated that further testing had provided this new value.
Old Aug 30, 2009 | 07:10 PM
Damian's Avatar
LSX Mechanic
You can use a very light amount of 30wt oil for lube. Been doing that for a long time.
I go 35-55-80, in that order using GM's sequence. Sit for an hour, go back and click them one more time @ 80 ft lbs.
Old Aug 30, 2009 | 07:30 PM
99blancoSS's Avatar
I wonder what made them test further? It was 70 for a long time. Did they start having some complaints?
Old Aug 31, 2009 | 04:41 AM
vettenuts's Avatar
Don't honestyl know. I removed my Darts last year and installed a set of AFR's. My Dart's were installed with the 70 lb-ft per the instructions and when I was talking to ARP they told me they increased the final torque number. One of the older guys there told me that "it was the new crew of youngsters they just got in and to just use the old 70 lb-ft number".
Old Aug 31, 2009 | 05:14 AM
PREDATOR-Z's Avatar
That is exactly how I went about it (30 weight oil). Hand twist (after thorough cleaning of holes), hand twist till reach bottom, back off a bit, then 30/50/75 and final pass after a good break.
They have been on almost 3 years with no issues.
Old Aug 31, 2009 | 03:11 PM
99LSS1's Avatar
Thanks for the Info guys!!! This will be written down for future reference.
Old Aug 31, 2009 | 03:43 PM
Damian's Avatar
LSX Mechanic
Actually there's no need to write it down. If you buy ARP studs new in the box, it comes with the instructions.
Old Aug 31, 2009 | 04:36 PM
JPH's Avatar
JPH
25/45/65/85 w/SAE30 wt. oil is what I do.
Old Sep 21, 2009 | 09:34 PM
69_YENKO's Avatar
Subscribing,
My short block already had the ARP studs installed so no instructions.
Old Nov 25, 2022 | 05:19 AM
Loneriderme's Avatar
Originally Posted by 69_YENKO
Subscribing,
yep they r in the box if they are new and mine say 30 60 90 which seems like a lot for aluminum heads?
Old Nov 25, 2022 | 07:16 PM
13 years later and you expect a reply???
Old Nov 25, 2022 | 07:34 PM
damn right I do. I got a reply and it was from u!! Lol
Old Nov 27, 2022 | 08:05 PM
wannafbody's Avatar
Well, according to testing, the ARP lube is more accurate than other types of lube for torque values.
Old Dec 16, 2022 | 01:12 PM
Dian's Avatar
can you say more on that? "accurate"?
Old Dec 16, 2022 | 01:34 PM
wannafbody's Avatar
Not really, I saw where Stacey David had a segment on ARP and that was their claim based on their testing. I can neither confirm nor deny.
Old Dec 25, 2022 | 08:17 AM
marvenednsson_'s Avatar
