243s
Old Sep 2, 2009 | 05:57 PM
ls2alex's Avatar
Default 243s
Basically, will the 243 heads off a 2006 gto, bolt right up in place of 2001 z28 heads
Old Sep 2, 2009 | 06:02 PM
jetlag's Avatar
Yes.... Mill them a little bit or run a thinner head gaskets for an extra bump in compression.
Old Sep 2, 2009 | 06:05 PM
ls2alex's Avatar
I thought so, I was just making sure
Old Sep 2, 2009 | 09:34 PM
BAD2000TA's Avatar
If you're keeping the stock cam, springs will be OK. But, change the springs if you go with a better cam. Also, change the pushrods no matter what. Stockers suck and might already be bent. Cheap insurance....
