Head Bolts?
Old Sep 2, 2009 | 09:32 PM
dwfronk's Avatar
Default Head Bolts?
I am doing a head swap on an LQ4 and i was wondering about the bolts. I am going to torque them to the specs that the motor came out of seeing as how the block is iron with aluminum heads. My question is do you have to replace the bolts every time the heads are swapped or can i just reuse the old bolts?
Old Sep 2, 2009 | 09:36 PM
BaddBird's Avatar
Do not reuse the old bolts. You could go with head studs and reuse those.
Old Sep 2, 2009 | 09:41 PM
conan's Avatar
Gm's head bolts are torque to yield, you streach them. They are a one time use. If you get ARP bolts or studs you can reuse them.
Old Sep 2, 2009 | 09:43 PM
dwfronk's Avatar
Thank you for the VERY quick reply that is exactly what i wanted to know.
