Spring replacement
Old Sep 3, 2009 | 03:07 PM
Jwright41's Avatar
Default Spring replacement
Was looking at getting a TSP 228R - 228/228 .588/.588 with a 114 LSA. My SS has stock heads with the stock springs. Im going to guess and say I need to replace the springs but seeing how it is a DD what would be the best springs for that? Will be putting on a new exhaust as well. I have looked around on a few threads but still not to clear about what springs to go with what kind of lift.
Old Sep 3, 2009 | 03:12 PM
Brandon35thSS's Avatar
im running that cam on a 112 lsa and im running comp 918's. no problems so far. you will get alot of different answers on this question. call texas speed and see what spring they recomend with that cam and run whatever they say.
Old Sep 3, 2009 | 03:14 PM
dont forget the hardened pushrods also,and other cam swap parts such as ud pulley,timing chain,oil pump.
Old Sep 3, 2009 | 03:20 PM
Jwright41's Avatar
Yeah I kind of figured on getting the package that had the springs and pushrods in it. They say to use PRC springs but Im thinking of spending the additional 50 and getting the PRC .675" Lift EHT Spring Kit. Would you happen to know what kind of pushrod length to get with that?
Old Sep 3, 2009 | 03:40 PM
02*C5's Avatar
Comp 921's
Once that is done I would check them every 50K miles for square, spring load and such to make sure they are still good. Some people say no worries, i have had 3 h/c packages on 3 different cars no issues or valve train failures doing preventative maintenance.
Old Sep 3, 2009 | 03:43 PM
Jwright41's Avatar
That is some good advice. I know that regular maintenance is a good thing. Appreciate the help on this.
Old Sep 3, 2009 | 03:49 PM
tsp recomended their 7.40 hardened pushrods with that cam when i bought mine so thats what i got.
