Swap from 241 to 243 heads?
I know of a set of 243 heads off a Z06 with patriot gold springs already installed with only around 2k miles on the springs. How much power would I gain with the swap on untouched 243 heads vs. leaving my stock heads on. Is it worth the swap? Also should I make a cam decision after I decide on buying the heads? Would the 243 heads work better with a different cam than what would be best for the 241's?
Wow you responded to your own post before I could lol......Id say go with the 2nd choice
However, if you can wait for ported, aftermarket heads, that's obviously the better choice. All depends on your budget.
also look at it this way. its about half the cost of a FAST intake/tb and worth about the same amount of horsepower, not to mention you get to tear in there and see if anything is wrong with your motor, top end!
