cam help?
Old Nov 28, 2003 | 12:00 PM
Quikws6's Avatar
Question cam help?
car:A4(ssf 3500), stock 3.23 gears, stock heads,with all the bolt ons....now on to the ? what cam would make awsome power and also have nice track times to with stock heads and perform even better when i get my stage 2 absolute heads. car is also daily driven....i was looking at the tsp 228R 228/228,.588",.588" 112lsa? not many people are running this cam so i havent found many results on it. Are there any other cams that would work better? thanks josh
Old Nov 28, 2003 | 12:09 PM
Z06PSI's Avatar
Get edit and a competent tuner and you'll be fine with any cam. Cam should work pretty good...
Old Nov 28, 2003 | 12:31 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
That's a good cam.
Look also into the TSP 231/237. I believe the guys over at TSP are fitting A4's with them successfully. Now THAT's a cam that will respond to Stage II heads.
Old Nov 28, 2003 | 02:06 PM
Jabroni's Avatar
For daily driven cars, a lot of folks are recommending something with a duration of around 224. That duration seems to be a popular one that is proving reliable without sacrificing drivability too much. Look at the TR224 or the C2 even.
