Hotcam before and after dyno sheet
. I did add spark plugs with the cam but old plugs were fine. Also added hardend pushrods.Without cam : 305.6hp 323tq sae corrected
With hotcam : 328.1hp 328tq sae corrected
With my current setup it looks almost like it could have a LS6 cam on the dyno sheet. But the idle doesn't
.I didn't drill the TB or mess with the stop screw either. Only drivability problems are surging a few secomds after hot start and if you rev the motor at idle(not the best for stop and go). I'll get a dyno tune after I install some LT's but stock tune will due until then.
More mods when I get the money. Just got the cam w/springs used for $200(checked before install). Already needed pushrods so it was a good excuse to install the cam now.
You would have gained more power and reliability doing all the bolt ons first. That being said, with all the proper bolt ons and a good full exhaust system, you should see ~370-380 rwhp with this cam on a good tune.
josh
josh
but as long as your happy with it thats all that matters. what springs cam with the cam setup you bought. depending on those too you'll be limited by a cam you could run if you so choose to get a new one in the future. if it were me i'd of just swapped out the pushrods that needed changing, that only takes an hour or so and called it a day.
The cam came with 2001 LS6 springs. I will have to replace the springs if I get a bigger cam, but as stated above thats not a problem for me. And if I sold the hotcam I would probly include the springs anyway.
In the words of Paul Harvey "Now you know the rest of the story".
With the graph starting at 0 and scaled by 50 hp on and the torque starting at 75 then scaled by 25 on the left, it makes it hard to objectively look at the graph for most of us.
I think you gave decent gain, but a lot of power is being left on the table. The shortie headers w/ 15/8 primaries to 1 1/2 with the hooker ones depending on the bends are killing you and the HPP3 tune isn't the best as it's not tailored to your set up. If you must run shorties, BBK has a new shorty with 1 3/4 primaries might helps some. The car needs Mac or LT's and a better tune IMO to make better power. ~360+ rwhp is well with in reach...
My 99 T/A made 323rwhp and 335 rwtq w/lid, dual/dual, stock manifolds, SLP MAF, plugs wires ie no HPP3, no shorties, no cam etc. Friend of mine's 00 Firehawk makes 326rwhp & 340rwtq with lid, corsa, stock manifolds, SLP MAF, plugs and wires, no other mods.
None of this is meant as a put down, you've got a excellent foundation to make more power with the a few additonal mods.
I don't put too much faith in dyno #'s since the 1/4 times are what really matter to me. But since its too late to goto the dragstrip I went to the dyno. I was also looking for this info before I needed the pushrods without much luck, so I though I'd post it incase others wanted to see.
I know the shorties and tuning give little benefit(possibly canceled out by the 12 bolt), but both were on the car when I bought it and it did not come with the HPP3 to return it to stock.
Hopefully I can get the money for LT's and dyno tuning before next season
. Add ET streets and I hope to see 11's
. Last edited by sleeperz28; Nov 8, 2003 at 03:48 PM.
1- Lid, Macs w/orp, magnaflow - 327rwhp 333rwtq
2- Above mods plus hotcam, LS6 intake w/28.6lb injs, Ported TB - 365 rwhp 372 rwtq.
http://www.tatommy.com/dynoruns.htm
I think you got a great deal for $200. Great hp to $ ratio!
Tommy
the ls1 in the fbody and the ls1 in the vette dyno within the same range, gm still wants to keep the idea that the vette is more powerful then its fbody brethern at a substantial cost less. vettes are still faster due to lighter weight and better aerodynamics but there pushin the same hp as you and me. factory ratings dont mean **** as you have found it. anyone in the know-how on the ls1 knows that the motors in the ls1 fbodies are underated, its just convincing those who arent in the know that the gm rated flywheel is what some of them put to the ground. average ls1 hp is around 300-310 depending on year and tranny.
