Problem replacing YellaTerra Platinum rockers ?
Hi Guys .
I have a problem with my LS1 Yella Terra Platinum Rockers Part # 6640 ?
Don't like the fact they are to wide and hit everywhere on Rocker covers .
And the side of the Head (Brand New AFR 225)
Also Towards the intake side of the head .Even on my Higher GM Performance Valve covers .
Anyway I want to replace them with some other brand rocker .
Maybe T&D or Jessels or even Comp Cams shafts .
Problem is in order to fit the YellaTerra Platinums I've had to drill and tap the standard 8mm Rocker bosses to the bigger 7/16" bolts that the Platinums use .
What are my options with regard to finding other brand rockers that take a 7/16" Stud/ Bolt ? Instead of a 8mm ?
Hi Guys .
