stroker kit
Do not settle for cast
thats my only adviceFordged steel is stronger then cast steel becouse its presurized and has no air pockets but billet has the smoothest surface least friction and its the strongest due to it being cut from a solid chunk of steel.
Cast is just a pour mold
Btw all you really need is a fordged steel 400 small block crank, conectiong rods, main bearing caps MAYBE if the cranks has bigger jurnels pistons ect et....
