408 hp/tq
Old Sep 11, 2009 | 05:42 AM
sobse's Avatar
Default 408 hp/tq
What sort of power fig would you see with a 408 with a big hyd stick(or stick setup to make big hp) ,afr 225 heads and fast 92/92 setup?
Old Sep 11, 2009 | 05:45 AM
alottaboost's Avatar
A lot... who knows really. Depends on MANY factors, even down to what brand of dyno you use.
Old Sep 11, 2009 | 06:36 AM
custm2500's Avatar
Ph.D. in HUBRIS
Teaxas Speed told me ~550 at the crank. Again depends on lots of factors.
Old Sep 11, 2009 | 10:04 AM
flatchat's Avatar
on the subject will some cnc l92's be better then say aftermarket cathedral heads
Old Sep 11, 2009 | 10:15 AM
Stroked96Bowtie's Avatar
I think that is a very conservative number. If you go big bump stick, should exceed that Id think. Take your time, do the research, never have a regret.
Old Sep 11, 2009 | 07:06 PM
custm2500's Avatar
Ph.D. in HUBRIS
I would agree that the numbers are conservative. But if I came on here and said It will make 600+ then I would have guys jumping down my throat that I am full of crap and what not. Therefore a 550 hp mark should be a reasonable guess.
Old Sep 11, 2009 | 10:45 PM
DVS99TRANS's Avatar
550-565whp should be easily obtainable, but you need a good tuner of course. If I have a MS3 on a 114(237/242, .603"/.609") and bumping that to a 250ish+ cam with better flowing heads unlike the PRC 5.3s I have on mine. Hell I still made 500whp on my setup. But you will need a unreal tuner closing in on 600whp with a NA 408. But if your auto, higher #'s like that will be hard to get.
Old Sep 12, 2009 | 11:15 AM
LS1-NAVY's Avatar
look in the dyno section there is a sticky called 408 part II read it, it will have everything u are looking for as numbers and builds go
