Another cam question
My question is will my stock 26lb injectors handle a 228/228 .585 112 LSA cam? with it I have some stock 241's with patriuot gold valve springs and they are milled, I don't know what the exact specs were for the milling I will find out from the guy I bought them from (mostly cause then i need to see about different length rods.)
I have not seen a solid answer on whether or not injectors are needed, but I also don't want to not have enough fuel either. I do appreciate any and all help on this. Thank you in advance.
