HOTCAM ques???
Old Sep 15, 2009 | 11:39 PM
nemss1's Avatar
Question HOTCAM ques???
im looking into getting a hotcam and have a couple of questions
LS1 and LS6 hotcams the same? isnt there just one?
also comparing the hotcam videos on youtube, what makes this guys hotcam idle different than other hotcam videos? what he has his idle set at maybe?
http://www.youtube.com/watch?v=VMS8dh6oT4w
Old Sep 15, 2009 | 11:42 PM
LS1-NAVY's Avatar
sounds like his idle is set high
Old Sep 15, 2009 | 11:43 PM
nemss1's Avatar
what would you say he is idling at?
Old Sep 15, 2009 | 11:45 PM
LS1-NAVY's Avatar
i have no idea
but what made u decide with the hot cam just curious?
Old Sep 15, 2009 | 11:47 PM
nemss1's Avatar
just way too many cams out there to decide on which gets mind boggling on a decision and wanting just something not so big. ive seen people call it the LS1 hotcam and LS6 hotcam. arent they all the same?
Old Sep 15, 2009 | 11:49 PM
LS1-NAVY's Avatar
im pretty sure they are the same
what are your goals/or what do u want from the cam
sound?
hp?
trq?
dd or not?
also what mods do you already have?
Old Sep 15, 2009 | 11:59 PM
blubyu02's Avatar
contact pat g he spec’d me 1 out 4 my app its going in soon Iwas like u at 1 time 2 many 2 chooze from and wanted 2 go big ieventually just paid the 25 bucks and was done with it
Old Sep 16, 2009 | 12:00 AM
nemss1's Avatar
Mainly looking for a cam not so noticeable. The cam on that gto almost sounds like a stock cam. I have a CIA, catback, UD pullies, gears, lower temp stat with fans programmed, headers and ORY as far as performance mods along with a crap-ton of weight reduction
Old Sep 16, 2009 | 12:02 AM
nemss1's Avatar
Not daily driven but does see the streets once in a blue moon
Old Sep 16, 2009 | 10:18 AM
slt200mph's Avatar
The best thing about the hot cam is the lope at idle...do yourself a favor and get something else......predatorz and patrick g are the two resident camshaft gurus contact one of them discuss your goals and they can spec one taylored to your specific needs.
Old Sep 16, 2009 | 11:19 AM
WeathermanShawn's Avatar
NemSS1:
Had the "Gm Hotcam" as my first cam. I am going on total memory here, but I believe the specs were ~219/228 .525 .525 112+3 LSA. Decent cam, especially mid range. I think the advantage at the time was you could get the total cam package (including valve springs) for a good price. The lobes were not exceptionally harsh and for a lower lift cam performed admirably.
That cam has ~0 overlap. I actually think it has a pretty nice lope. You could definitely tell it was not a stock cam. From that idle clip, sounds like the operator has a fairly high idle and a lot of spark advance. So the lope is perhaps a little muted.
If the other cam that you are referring to is the LS6 cam, that is a totally different animal. As far as I am aware there is only one GM Hotcam. Things are always changing, so if I am wrong..someone please clarify.
There are so many newer lobes and cam technology now, that the choices today are endless. If you are trying to retain a 'stock' idle, go for a 220/220 114 LSA, or a cam with a total overlap of < -6 degrees.
Hope that helps.
..WeathermanShawn..
Old Sep 16, 2009 | 11:40 AM
caged02's Avatar
The GM Hotcam was my first cam I installed in a LS1. I was really surprised how good it sounded. I ran the SLP 1.85 rockers with it and long tubes in a 02Z28 and the car made 385 rwhp.
Old Sep 16, 2009 | 12:48 PM
nemss1's Avatar
Thanx for all the info guys. I'll def look into getting a custom-grind
