Single roller chain
Old Sep 16, 2009 | 03:33 PM
Monte4ever's Avatar
Default Single roller chain
I'm putting together a 402 iron LS1 which will be used with an F1A in the future. I want to know if the LS2 HD single roller timing set will be enough. I'm looking to get 750 -800hp when its all said and done. Double rollers usually require spacers and grinding on the front cover and are sometimes not necessary. I only plan on revving to 6800 - 7000. Also, do you think a single would be good for longevity. Thank you.
Old Sep 16, 2009 | 03:41 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
It has been said time and time again....but the IRL (rain) chain from Cloyes is one of the best single roller chains around as well as the C5R chain. We have the last remaining stock of the IRL chains here at scoggin posted around in a few threads. we sell them individually or with the hex -a- just timing chain kit. the whole kit is a little pricey at 339.95 but def the last single roller set you should ever need. They are fully adjustable in quite a few different ways. Just 2 of the better options avail
Old Sep 16, 2009 | 04:31 PM
1sick'98WS6's Avatar
I would go with a C5R chain if you dont need the adjust ability. Its a direct swap and is only 125
Old Sep 16, 2009 | 04:32 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
well the IRL chain can be sold alone just like the C5R but like i said it is more money than the C5R also
Old Sep 16, 2009 | 04:48 PM
JPH's Avatar
JPH
Pro-Gear #PG4210 should do the job for you, and it's $99 bucks.
Old Sep 16, 2009 | 07:36 PM
Monte4ever's Avatar
Thanks everybody. What do you think about the Comp Cams 3153kt timing set.
Old Sep 16, 2009 | 07:54 PM
vsocks1's Avatar
Get the Cloyes IRL with Hex Adjust as John suggested above!
I don't think $339 is too much for the best adjustable available....and some piece of mind!
Old Sep 16, 2009 | 09:28 PM
Monte4ever's Avatar
Cloyes IRL it is. I ordered my EPP blower cam and Mellings HV oil pump earlier so I'm on my way. Thanks for pointing me in the right direction.
Old Sep 17, 2009 | 08:55 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
i think it is very strange that comp has the same part number that cloyes has for it dont you? lol.
Beau@SDPC's Avatar
LS1Tech Sponsor
and horace.....thanks for the order!
Old Sep 17, 2009 | 11:16 AM
Monte4ever's Avatar
Thank you for the help and support. Trying to do it right the first time.
Old Sep 17, 2009 | 11:17 AM
Monte4ever's Avatar
Strange it is.
