will it hold?
Old Sep 16, 2009 | 10:53 PM
1nasty86's Avatar
Turd Gen Guy
Default will it hold?
stock bottom end lq9 with lq4 pistons. im planning on upgrading to the arp rod bolts, fresh bearings and rings. planning on running 10-12 psi with a 88mm turbo, 317 heads and studs of course. victor jr. with elbow. with a turbo 350. will it hold untill i can afford a forged rotating assembly and better heads? if necessary i can run a lower psi.
Old Sep 17, 2009 | 08:01 AM
conan's Avatar
With a GOOD/SAFE tune you should fine with that much boost. Whats the compression with the lq4 pistons?
Old Sep 17, 2009 | 08:28 AM
Old Geezer's Avatar
Lq4 = 9.4:1.
Old Sep 17, 2009 | 09:49 AM
PREDATOR-Z's Avatar
Why an LQ9 with LQ4 pistons? Why not just a LQ4 and change the rod bolts.
Old Sep 17, 2009 | 01:02 PM
1nasty86's Avatar
Turd Gen Guy
because thats just how i got it.
Old Sep 17, 2009 | 01:25 PM
hellbents10's Avatar
LS1Tech Sponsor
LQ9 rods are better anyhow, should be fine to 800fwhp with good fuel.
Old Sep 17, 2009 | 03:28 PM
1nasty86's Avatar
Turd Gen Guy
ok. i know this isnt the fi room. but how much psi would be "safe'?
