valve to piston clearance issue
Old Sep 17, 2009 | 08:19 PM
pushwood88's Avatar
Default valve to piston clearance issue
i just bought an mti stealth 2 cam and i know with everything else stock ill have good clearance and im putting on a set of 243 that i know will still be fine but what about if on top of the .581/.581 lift i put on slp 1.85 rocker arms? and i was thinking about milling downs the heads to get 11:1 compression? will i have clearance with the cam and milling? what if i put on the rockers? i may or may not use the rockers and sell them if its too much of a hassle.
Old Sep 18, 2009 | 04:49 AM
vettenuts's Avatar
Measure prior to milling, then subtract mill to see where you stand with clearance prior to actually milling the heads.
