How to get 11.1 compression in a LQ4
Old Sep 21, 2009 | 11:11 PM
Jeff Smith's Avatar
Subscribing...
Old Sep 22, 2009 | 05:06 AM
ramdaspadhye's Avatar
Originally Posted by Soul TKR
If your just gonna do a 224 cam, look at my setup... I'm right at 11.2:1 compression with an LQ4 and a 224R cam... My heads are milled to 59cc with the stock dished pistons. Runs great!
How are you at 11:1 compression? Is that calculated SCR with the cam or just a piston/combustion chamber calculation?
Old Sep 22, 2009 | 05:33 AM
PREDATOR-Z's Avatar
IIRC, dish in LQ4 pistons are ~6.7cc can anyone confirm please.
Old Sep 22, 2009 | 01:13 PM
NemeSS's Avatar
Originally Posted by 99 Blue Bird
thanks for the info NemeSS. one more thing. whats the cr on your motor? and do you dd your car?
10.8:1 scr with dished lq4 .060 over pistons and 4cc valve relives
milled 243 heads .030.
4.085 bore .051 compressed gasket
+.015 deck
stock crank,rods, .060 over 8cc dish piston
if i would not have machined in the vr's it would be right at 11:1 even with dished pistons and the milled 243 and .051 gasket.
the piston protrudes .015 out of the bore.
SD tune
mostly weekend and gtg car. i dont dd as much anymore, but i use dd it for about a yr after i built engine. engine has around 40k miles now.
avg. about 23mpg with t56 full weight and 18in wheels
pistons used are Speed Pro part number:
H857CP (8) 99-02 VORTEC 364CI (6.0) 250.00$
1.5/1.5/3.0MM Sealed Power Rings (4.00-4.06) bore 100$
coated skirts, press fit stock rods.
Old Sep 23, 2009 | 07:19 PM
99 Blue Bird's Avatar
does anyone else have any good rods and piston brands to reccomend?
Old Sep 23, 2009 | 08:14 PM
elias_799's Avatar
i got coated wiseco pistons and compstar rods in my turbo motor, and no problems yet
Old Sep 23, 2009 | 09:23 PM
So 11:1 compression on a stock LQ4 would be 59cc chamber heads with a .041 gasket, correct?
Old Sep 24, 2009 | 01:38 PM
NemeSS's Avatar
a stock lq4 is around +.010 deck, a .041 gasket would net .031 quench.
perhaps a bit on the tight side. i try to keep it around .035-.040
u will have to verify ptv for sure with that gasket. even though the spherical dish does allow for some valve clearance,
with a .041 compressed gasket (assuming the bore is around 4.08) and 59cc chamber heads, SCR will be at around 11.31:1 with a lq4
Old Sep 24, 2009 | 02:11 PM
and the GM 6.0 MLS gasket is how thick?
Old Sep 24, 2009 | 02:49 PM
NemeSS's Avatar
ls3 is around 4.085 .051 compressed
Old Sep 24, 2009 | 03:19 PM
novaflash2002's Avatar
lq4 head gaskets are 4.045 bore compressed .051 compressed thickness
Old Sep 24, 2009 | 03:38 PM
  #32
NemeSS's Avatar
i measured them at same bore, but iirc the compressed thickness was .055
Old Sep 24, 2009 | 06:17 PM
  #33
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
We also have a 227 runner with a small chamber in the new PRC castings! It's available with small chambers for kicking the compression up!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Sep 25, 2009 | 12:17 PM
  #34
NemeSS's Avatar
any more info?
chamber bore? cc? valves? flow?
Old Jan 7, 2011 | 06:22 PM
  #35
Kory 88Iroc Lt1's Avatar
great info.
bookmarking for future project.
Thanks,
kory
