Quench question
The idea is to make it as tight as possible without the piston hitting, correct??
If stock gasket thickness is .051 compressed, I should be able to run an .041 gasket without any worries?? Shift rpm is only 5500 but it will not be EFI.
Most LS engines use a positive deck clearance (not 100% certain on LQ4 & LQ4) meaning that the piston extends a few thousandths above the deck surface at TDC. Older Gen I small block chevy's were well below the deck unless the block had been machined.
Aside from that, you need to have a little room for the pistons to rock at TDC. You can measure with a dial indicator on opposite sides of the pin (intake side vs. Exhaust side) but this distance should be minimal.
Lastly, you do need a little room for error and stretch as RPM's increase. With your 5500 rpm shift points, you should be fine for this exercise. Once you have changed parts in the bottom end though, it would be safer to measure, especially if you plan to push the limits.
Good luck!
Is that a lot of slop in the bore??
I can still see some of the hone marks in the cylinder.
https://ls1tech.com/forums/advanced-...-rock-tdc.html
My "little fella" cam duration is only 210 int, 218 exh, .531 lift with 114 LSA.
I am fairly certain there should be enough piston to valve clearance, with only .020 removal of gasket and head (total), but if anyone thinks otherwise please let me know.
