Having bucking issues at low rpm
Old Sep 24, 2009 | 05:59 PM
00_Z-28's Avatar
Default Having bucking issues at low rpm
Ever since I have put my converter in I have had a slight bucking issue at low rpms. The car has the stock cam and the converter is 3200 as stated in my sig. I have kinda just delt with it but I have noticed my car is starting to run rich and so my question is. Should I have this checked out? is it something to worry about? Car runs fine seems like just that bucking at low rpm till it down shifts and then everythings fine. My guess is is that its a tuunning issue what do you think?
Old Sep 24, 2009 | 06:05 PM
MUSTANGBRKR02's Avatar
Was it tuned after the stall? If not this is your issue.
Old Sep 24, 2009 | 06:49 PM
00_Z-28's Avatar
Yes it was but not dyno tuned just a very basic tune do I need something more substantial?
Old Sep 24, 2009 | 07:00 PM
sounds like you are having airflow issues in the tune. Do the RPM's drop or doest it stall when put into reverse? Is there any surging when coming to a stop?
Old Sep 24, 2009 | 11:18 PM
00_Z-28's Avatar
no, no, and no. Like I said it runs wonderfull in everything but when I just give it a little gas going say 30-60 and it bucks then drops down into a lower gear and dose just fine.
