cam swap going too good.........
Old Oct 3, 2009 | 09:55 AM
EndlessSummer85's Avatar
lol yea I was thinking the same thing when I was doing my cam swap, then I dropped the oil pump pick up tube bolt..... took me a little over an hour to get it out of the pan with a magnet. LOL that sucked, other than that things went well, the #7 cyl and #8 cyl valve springs are fun to change too, cut my arm all up under the cowling....
Old Oct 3, 2009 | 10:29 PM
eseibel67's Avatar
^ Shredded forearms are caused by the little black plastic snap tabs that hold the cowl-to-hood weather seal down.
Next time, pop them out before you start taking the coil brackets off.
Old Oct 4, 2009 | 05:17 PM
eallanboggs's Avatar
Shop rags in the pan keeps bolt from dropping. Shop rags on the heads catch dropped keepers.
Old Oct 4, 2009 | 05:58 PM
SuperSlow02's Avatar
I used fishing line, back the bolt out a lil bit then tied the line around it, and wala, no more dropped bolt, hella useful when putting it back on
