fan wont turn on!
the temp get to 220* and the fans didn't kick on so i checked the tune and they were set to come on at 165* .....so i opened the scanner and checked the DTC's in the scanner. Well it brings up the relay falure for the fans!
I did cut and reverse the wires on the pigtails for both fans to run them backwards... but that shouldn't cause the problem! should it?
thanks for the help guys!
anyone have any ideas???????
I did a motor swap on this project also so the harness came out....what wires whould i check?
thermostat is opening, tune is good for fans (i have hp tuners), BUT when i check the pins for the fan relays they have no power!
All i did was swap the wires around so the fans would run backwards... everything else is working except the fans!
Anyone have a wiring harness diagram or an idea of a wire to check???
