Whats the difference between lq4 and lq9 short blocks????
Old Sep 27, 2009 | 08:20 PM
PINKYPINKY's Avatar
Default Whats the difference between lq4 and lq9 short blocks????
I wanna put a iron block in my car but not to sure what the differences are between the lq4 and lq9 if any??? I thought that the heads were different but whats different about the short blocks??? Thanks!!!
Old Sep 27, 2009 | 11:34 PM
TURBO6.0L's Avatar
LQ4 has dished piston with compression ratio of 9.4:1 and LQ9 has flat top piston with compression ratio of 10:1. LQ9 is supposed to have better rods and pistons. They both should have the same 317 casting number heads which are just a larger combustion chambered version of the LS6 heads. Bare blocks are the same.
Old Sep 27, 2009 | 11:48 PM
PINKYPINKY's Avatar
Ok really i just wanted to make sure the blocks were the same... And i planned on running the 317 head with a good forged rotater with boost so i wanted to make sure on the blocks!! I found a 60k lq4 block only for $150 so i didnt wanna buy it without knowing... Thanks!!
Old Sep 27, 2009 | 11:50 PM
PINKYPINKY's Avatar
How do you like that sts kit?? You make decent power with it?? Whats done to your motor??
Old Sep 28, 2009 | 01:25 AM
TURBO6.0L's Avatar
PM sent.
Old Sep 28, 2009 | 04:35 AM
frankmarroquin's Avatar
Exactly whahe said...
Old Sep 28, 2009 | 11:13 AM
Fbodyjunkie06's Avatar
Yes LQ4's have lower compression due to dished pistons and the LQ9 has flat-top pistons yielding a higher compression ratio. Heads are the same 317 casting for both.
