Pic of yellow crap under oil cap
I usually start mine and let it sit for around 45 seconds.. Just long enough for the oil to circulate.. If 45 seconds is going to make you late then it didn't matter anyways..
I take it easy the first minute or two driving then go WOT the rest of the way to my destination.
If you've been doing this for a while now, I'd take the time to inspect the PCV lines. Replace PCV valve if contaminated. Possibly the stuff will be caked onto the valve covers as well. Should do an oil change too since if it can't really get rid of the moisture, this stuff makes the oil more acidic.
1. Change the oil every 3 months.
2. Check PCV system, bet it needs TLC.
3. Add a catch can (RevXtreme).
4. Let it warm up for a minute or 3.
5. It will eventually shorten the life of your engine.
Head gasket issues happen, but aren't very common. The only cooling problems we routinely see on LS motors are water pumps shitting the bed and gunk in the radiator due to a poorly sealed system. Simply flush the coolant every 2 years.
You do all those things, and the yellow gunk will all but disappear.
I still see 6.0 in my future... with a decent catch can, and hopefully a little longer drive to work.
I take the "scenic" route to work when I have to use a car.
It adds about 10 minutes but, the engine thanks me for it.
It is at WOT temp just as I pull in to the parking lot.
If the weather is real nice, it's the Fatboy on the tarmac.
600 lbs being pulled by 165 hp twin cylinder stump puller...LOL
Love my WS6 but, nothin compares to 0 to 60 in about 2.5 seconds....and 35 mpg LOL
