View Poll Results: Cam, nitrous or suspension?
Cam
11
28.21%
Nitrous
19
48.72%
Suspension
9
23.08%
Voters: 39. You may not vote on this poll
Cam or Nitrous next???
Old Oct 10, 2009 | 06:29 PM
Johns00Z28's Avatar
Originally Posted by BennyB
Awesome! This is what i was looking for. Thanks for all the responses... definetly helped me make up my mind. Everything makes sense here... Nitrous it is. Thanks again guys.
How well do you think you'll hook up with 450-500rwhp and no suspension mods?
Old Oct 11, 2009 | 02:35 AM
IWGF's Avatar
From a 3rd gear roll, he'll hook just fine... Put power down, then worry about suspension.
Old Oct 11, 2009 | 08:36 AM
Johns00Z28's Avatar
From his 1st post he was talking about the 1/8 mile, not from a roll.
Old Oct 11, 2009 | 08:12 PM
wildbird02's Avatar
Subframe connectors/suspension. Get that bod ready for the power to do some launches and don't tweek that body.
Old Oct 11, 2009 | 09:08 PM
IWGF's Avatar
Everyone should roll race every once and a while
JK, guess I missed that. Well, with a proper nitrous setup and window switch, he could lock out 1st gear from spraying. Or just throw on some nice sticky tires and work on his launch.
Old Oct 11, 2009 | 10:20 PM
Fbodyjunkie06's Avatar
I voted suspension. LCA's, relocating brackets, rear sway bar, tq. arm, hals/qa1's=sub 1.70 60 fts...
Old Oct 12, 2009 | 01:50 AM
'91firebirdformula's Avatar
he kind of left out that he also has an ss4000 converter, slicks mounted, and 4.30 gears. he will hit sub 1.7 60's the way he sits. gotta agree with some of the suspension things. throw a 150 at it ben. then go hit a 6.9 1/8th.
Old Oct 12, 2009 | 01:57 AM
WS6RED2002TA's Avatar
If your going to do the 408, then the cam is a waste of money.IMO I would save up for the supension and spray. I would do them at the same time. Good luck
Old Oct 12, 2009 | 07:12 AM
Johns00Z28's Avatar
He said he'd get a 408 when his LS1 goes....who knows how long that could be if it only has 70k miles...it could last until 200k and another 8 years. lol
Old Oct 12, 2009 | 10:15 AM
It sounds like the OP can only afford one or the other. Which is the whole reason for the thread in the first place. By using that assumtion it might take him 8 years to save up for a 408. Also when you use spray, engine's tend not to last as long. IMO
Old Oct 12, 2009 | 10:31 AM
IWGF's Avatar
Right on! N20!!!
Old Oct 12, 2009 | 10:47 AM
  #32
Johns00Z28's Avatar
Yeah that's a valid point which is why I said cam if he's not planning on getting the 408 anytime soon. It'd be a little easier on the motor and give him enough to run a respectable time at the track.
Old Oct 13, 2009 | 08:30 PM
  #33
99T/AMAN's Avatar
suspension is my vote and if he wants to bracket race then a cam would be better for running the same time everytime
