is it ok to reuse factory head bolts
#61
The proof is in the pudding. In stock application with MLS type gaskets LS engines simply do not have head gasket failures. I dont know of a single FACTORY installed head with GM TTY bolts that has ever let go. That tells the story for itself right there.
With above post re ARP is for serious use, by serious racers, who need serious strength plus the added bonus of being re-usable. Simply installing ARP bolts or studs and walk away forget it forever as you can with stock tty botls? Probably not very wise. One quick search of the many ARP balancer bolts coming loose can prove that for you. For any street driven car the tty bolts are the best way to go.
#62
So to answer the OPs question yes the bolts can be reused but you won't have an accurate way to measure the torque needed to attain the desired clamping force. Torqueing the used bolt to the same torque specification as the new bolt will not give you the same clamping load and how much more torque is needed is just a guessing game.
#63
Thanks.
#69
it honestly scares me a little that guys out there are taking short cuts like these, and defending their actions. for the cost of new headbolts, why would you? so what if someone got away with it making a grand of ponies with boost? if you were doing lemons or a roadkill-clone episode on youtube, yeah ok, i get it. it doesn't make it ok on my car.
if it's my car, i would want to do it right. if i make a mistake or do it wrong, when it's something as important as a head gasket seal, it's out of ignorance and i would want to be corrected and feel like an idiot for doing it wrong, not insist i was right to do it the wrong way.
that's just me i guess.
#70
When ANY of you have as much experience as ME<actual 47 years working on engines> and actually tried reusing the bolts and they FAIL<which aint never gonna happen by the way> then I may agree but until then I say YOU CAN USE THEM because I've seen it done without any problems.
#71
Do a search on this site, plenty of guys reused them. PM them and ask what they did. Some guys with high HP motors too. Not sure why but when ever this subject comes up everyone gets to name calling and bunched up panties.
#72
#73
Exactly.
As far as reusing head bolts and can you, of course you can.. Plenty of people have played russian roulette and not died, but many have. I just prefer not to play it. Especially when it costs $30 to avoid it.
At a certain point people start to value their time over saving a buck, and wise people know it's cheaper to do it right the first time.
#74
The OP of this thread asked for OPINION on reusing head bolts. Whether people like it or not people do reuse these head bolts. What I don't understand is why everyone acts like the world is going to end if they reuse them. I seen tests done by some very knowledgeable engineers on used bolts that showed they could be reused.
Bottom line, just because you CAN do something does not always mean it's a good idea.
#75
raise your hand if you've lifted a head/pushed water on an ls.
now put your hand down if you made in excess of 1000 wheel
for most of us 500 - 600 wheel guys, reusing stock bolts is fine.
most of us will bust a ring land or bend a rod waaay before a head lifts.
if you need the extra peace of mind, ****** do it. its a free country.
just don't act like those of us who don't are fools playing with a live grenade
#77
Sorry but someone has to know something around here. LMAO Ya know you guyz keep calling me names because you don't agree with me. Don't children do such stupid things? It surprise's me how immature you all are.
I tended to follow the advice of the expert engine builders I've known several in NASCAR and I don't think any of them would put their name and reputation on an engine with a reused TTY GM head bolt regardless of what someone else might claim about it being OK to do. None of the NASCAR engine builders I've known would reuse a TTY GM head bolts bolt. They would replace it with a better bolt or a new TTY GM head bolt.
There a big difference in doing something for 47 years and doing it right way for 47 years
I've known guys that call themselves master engine builders that put pistons in with the valve relief turned the wrong way. I knew another expert that didn't think honing was needed if you carefully bored the block.
YMMV
#78
I don't care if a person has 2 years or 70 years experience if they know what they are doing, Some of the smartest people I have met have had only a few years experience in their line of work and know more than someone who 3x as much experience.
I don't claim to be a better than everyone else, I know plenty who are smarter than me but I also have met plenty who claim to be a genius that can't understand basic principles.
A very knowledgeable engineer would not say they are ok to be reused, That would go against everything they were taught.
They will work but as I said earlier you can't just guess at how far to tighten them and using the stock procedures.
Of all the things to save money on I can't see why anyone would want to reuse TTY bolts.
I know I have enough money into my engines that it would be crazy to try to save a few bucks and they aren't anything special.
#79
He's probably been doing oil changes on engines, when he wasn't sweeping the floor....
#80
Fastener Service Life = Time of Use
Hi ALL, I work with Racing Engines with a Fastener Life Requirement CHANGE based on service time.
They are replaced, look as new, Mag OK, measure as new.
The problem is that if this is NOT DONE, the Warranty is VOIDED.
COULD they know a few things ?
Lance
Lance
