Cam and heads question for an Iron 422
Motor will be a standard forged iron block 422 from an LS1tech sponsor (4.030 bore x 4.125 stroke).
I need some suggestions on cam selection that keeps low end torque and doesn't require it to spin past 6500. Needs to idle well and have excellent throttle response. Reverse split due to intake?
What should we look for in a set of heads for this cubed motor? I don't think we would want compression past 10.5:1 (unless someone convinces me otherwise). I'm afraid of low rpms under load with this much weight. Must be able to run on 92 to 93 octane with no problems.
Any help would be very much appreciated. We are not expecting 500 hp from this Escalade, but 450 hp and 500 tq would be nice. <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" />
Richard
THe above suggested H/C set up on a 112 lsa has put Nineball into the 10.6 range (N/A on his 436cid) and he uses his car as a daily driver and it is reliable as heck. This set up has also put many LS1 into the 10s on motor and some in the 9s on spray and of course its biggest claim to fame is putting the COLONEL's f body in the 9.8 et range on MOTOR and no spray on MTI's 422 cubed resleeved alum block.
May as well spend the little extra $ and go with a proven winner.
Best of luck,
MTI 427 C5 Roadster
Certainly there is a better camshaft than the S1 for this project. I'm not knocking the S1, its just that a daily driver Escalade will require different things from this motor than most C5s would. It will have a mild stall, need super tame street manners and idle well.
I think we are willing to give up a little from the max power of the 422 to get a super torquey street sleeper vehicle with good manners. Know what I mean?
The R1 cam specs may be perfect with specs of 232/237, .560 lift and 114 lsa. The R1 cam may be just what the doctor ordered. Check it out and do some research on it and of course talk to the guys at MTI on the R1.
MTI 427 C5 Roadster <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
1) Does it need to pass emissions? I'm not sure how much duration you can get away with but I am thinking maybe mid 23x's duration with like a 115-116 LSA will idle well and pass emissions... not sure though.
2) Are you towing too? I'd keep it under 11:1 not sure how the load of towing 5000-7000 lbs will contribute to possible detonation issues.
I had a 244/244/114 idled well but still a bit choppy..
I have a 242/242//112 and it's noticeably more lopey.
john
ARE 422ci iron
Since we are in Texas, we can register the truck at the farms address and have no emissions testing. I'm thinking we will keep high flow cats on it, but might opt for some cutouts before them.
I doubt that it will be any kind of tow vehicle, but there definitely wont be any weight reductions to it. More like weight additions, in the way of audio video components and other stuff. Now, I wouldn't put it past this guy to hook up a trailer and try to outrun his neighbors powerstroke. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
If it were for me, I'd be driving to Nebraska to meet up with you. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
