Help. 2 quick sparks and then none
Old Oct 10, 2009 | 07:42 PM
Shakenbake01's Avatar
Default Help. 2 quick sparks and then none
I searched for an hour or so and cant find a solution. I have a 2002 LS1 and a 99 computer. When the ignition is turned on there are 2 quick sparks. When I crank the car it sparks for a second or two and then quits. The VATS has been disabled in the computer. Also the computer is only putting out 8.3 volts on the fuel pump signal wire. I have to wire the fuel pump relay coil directly to an ignition source to get the pump to work. Thanks
