383 vs 402/408
The 383 specd to the bare minimum of hitting his goals is around $6800 but that's using his LS6 intake and does not include injectors. A 408 with LS3/L92 heads an L76 intake with injectors and a ported 92TB is around $7900. That doesn't include the kit to convert the TB though. I thought he could sell his LS6 intake and 85mm TB and recoup some money and either way he goes he's ready to put in a new trans/rear on top of that.
Another option he has is he already has a really clean LQ4 at his house and he could build it into a 408.
I guess my question is what's the best way to make a 10 second sleeper street TA for the least money that will still be reliable?
So I guess my vote goes to the 408 with L92's especially if you already have the LQ4 as a starting point. Hell you could even use the LQ4 forge it and make into a 370 and spray the hell out of it.
That didn't take long...I specd it out the same and it was $700 more for the alum block 402 as it costs a little more and requires a conversion kit to make it work.
Listen to me: build a killer 347. TFS/AFR heads, the works. Put the rest in the rear and suspension, etc. You can make your goal with a healthy, streetable cam. Just get it tuned by the best.
Good luck.
