Priming
Old Oct 16, 2009 | 12:57 AM
the_merv's Avatar
Default Priming
Is there any way to prine these Engines besides Pulling the Ignition & Injector Fuses and turning it over with the Starter till the Gauge moves?
Old Oct 16, 2009 | 07:18 AM
mknight759's Avatar
there is a plug on the drivers side front of engine you can remove then use a hand pump to force oil through the engine but the way you described works and is fast
Old Oct 16, 2009 | 07:34 AM
the_merv's Avatar
Is that the one that is a Hex Plug right behind the Alternator..well in that area?
Old Oct 16, 2009 | 10:31 AM
01ssreda4's Avatar
Tried and true way works best. Or get that drill extension to plug in where the distributor goes
Old Oct 16, 2009 | 10:51 AM
bigboykilroy's Avatar
I bet someone will ask, where is the distributor hole is at....
Old Oct 16, 2009 | 11:31 AM
the_merv's Avatar
^^Lol I've seen LS Engines with Distrubutors..
Old Oct 16, 2009 | 09:55 PM
WhiteRhino's Avatar
I was leary about the crank to prime too. It did work well for my 383 though. I did a couple 10-20 second bursts and my pressure got up to about 15-20psi. I didn't do it for more than a couple minutes total. Plugged in the fuses and it fired right up with about 60 psi cold.
Old Oct 16, 2009 | 11:57 PM
the_merv's Avatar
That's what I was plannin on doing..crank it over right before I put in the Plugs, then put them in and fire it up.
Old Oct 17, 2009 | 12:07 AM
conan's Avatar
It will turn over effortlessly with out the plugs in. Did you dump any oil on the valve train before you put the rocker covers on?
