Major engine problems with JPR 388
Old Dec 7, 2003 | 11:43 PM
  #161
fatrat's Avatar
Thumbs up just trying to help,i recieved an email from a couple of friends about your problem.
Originally Posted by ezss
My car has been at JD's auto repair now since last monday. I took the car there because Joe Prince @ JPR recommended taking it there, saying that JD is handling the install portion of his business now. As many of you know, I have had problems with the car since day one with the new engine. It dynoes well, but it smokes like a **** going down the track and I can not get good times out of it, it seems to have a loss of power in the upper rpm band, and just feels flat. Before the 388, best ET 11.87 @ 118, after breakin and exactly the same setup I go to atco and I cannot get the car to run faster than 116mph trap times (and slower ETs too). I thought it was just that I was a bad driver, and the clutch is tricky, but at that time it was working fine.
Back and forth with JPR, changed cams, changed cylender heads, changed injectors (twice), multiple retunes, LS6 oil management system, new rockers, the list goes on and on. The original project budget was $5500, went up to $7500, and now I have over $12k into the car's motor this year alone. I paid for everything, except I was given a break on the second cam install. Now I am told it will take $5-6k to get my car running again because of the following:
1. collapsed lifters, five (5) of them. I have never heard of Comp R racing lifters collapsing
2. glazed cylender walls -- JD says they look like a very old car's, and had to be re-honed (work already done), which will require new forged pistons and new piston rings (which were apparently shot anyhow). Stretched rods, which initially said would require new rods, but now apparently are salvageable
3. rework needed on cylender heads, with only 1500 miles on the heads, they need to be reworked for $300.
4. recommends going to solid roller and lifters because hydraulic will not hold up to 7k rpm.
They are telling me this is because i overreved the motor (at 7k rpm?! this is the rev limiter on nearly every h/c out there, and I have doublesprings,yella terra rockers, hardened pushrods, comp R lifters, forged internals, and every upgradeable part imaginable). I believe it to be a setup issue, I do not understand how you can collapse that many lifters and do the damage that was done any other way.
They are also telling me this is because I upgraded to 42# injectors from 36# (car wouldnt even start), which was done at JDs recommedation because JPR had no opinion on why my car appeared to running out of fuel in the upper rpm band on the dyno. The computer was sent in, without ever moving the car (it wouldnt start, bogged right away) once the injectors were put in to Bryan Herter, who did the tuning at JDs and both JD and Bryan said it should not be a big deal to make this adjustment. I autotapped the car when i got it back and it ran, found it to be running very rich still, and adjusted the tuning with a MAF Translator until it went back on the dyno again. Anyhow the injectors are cited as the reason why the cylenders are screwed up, the rest of the damage from overreving.
My theory? Valvetrain set up wrong, too much preload or some other issue, collapsed the lifters and the valves would not open all the way, forcing unburnt gas back in the cylenders, causing excess crankcase pressure and the oil problem (which incidentally the last time I ran they kicked me off the track for the huge cloud of smoke I took down the track, and oil was everywhere in my engine bay, pooled on the airfilter, on my strut tower bar, pooled in the intake, everywhere.) I wouls appreciate other people's thoughts that are more technically oriented than myself on how all of this could have happened.
Either way, I cant see how I should have to pay all this additional money on top of the $12k into the motor just to get me up and running. The car has been there two weeks, Joe prince apparently works for JD now, and neither of them will give me any kind of break or special consideration under the circumstances. I have tried to contact JPR, but he has not called,emailed me or anything and he knows from JD also that I have been urgently trying to get in touch with him.
I am at my wits end here, I cannot afford to keep the car as it is, and now Im asked to spend 5-6k just to get it back to where it was supposed to be in february?!?
I offered to make deals, for instance I have said I can justify in my mind (even this is pushing it) to pay for new pistons, rods, etc...if the engine is upgraded with a stroker crank to a 427. The parts for this come out to $4k (with JDs markup), but for some reason it will cost me close to $8k to make this change. I said I would do $5k everything included in light of the situation, but thats not workable apparently.
I have video, timeslips, and every email every passed between JPR and myself, and it looks like I am going to need it if I have to file suit. This has been the single worst automotive experience I have ever had, and the entire process along with the fact that I cannot afford to keep the car any longer because of balooning debt to pay for all this, has really left a sour taste in my mouth for the LS1 modification scene.
It looks like I am getting out. If anyone wants to make me an offer on the car as is, or has suggestions on how to get it fixed maybe using a stock motor, let me know. It can be a 427 soild roller setup with another 5-8k into it that should see north of 500rwhp/500rwtq NA. All specs and mods on my webpage:
www.erikz.org I will possible part it out, depending on who is interested in what, with dibs going to members of the SLFBA, my car club. This saddens me greatly, I have always wanted a camaro, I have camaro posters and hundreds of camaro miniature cars, tons of camaro memoriobilia, etc... that will require some redocoration/relocation in my house.
Thank you JPR for standing behind your work
iam almost positive if you install an electric vacume pump with a #10 hose t-fitting with 1 #10 hose going to left bank valve cover and at the t fitting install a cheap vacume guage. the right bank vale cover must be sealed off of any breathers or sensors.
sounds like your crankcase pressures are to high underneath the the piston rings causing the blowbuy....
Old Dec 8, 2003 | 07:03 AM
  #162
George C.'s Avatar
JD I am not so worried about how the engine will come out, as I am about the warranty AFTER. I am in the High End Customer Service business. This IS what I do for a living. I know first hand that people are realists and they know that things break or go wrong. MOST people are understanding, but they do expect to be taken care of IF there is a problem. What % and who is at fault should be agreed upon mutually and hands shook, and motors fixed. If my car has smoking issues, who do I call? I cant/wont bring my car to your shop 99% because of the location. I moved further away than I used to live from Joe so now he is far, and you are even further. I used u once for a dyno tune and I was happy with the shop. I need a LOCAL guy to tune and do the little things on a regular basis. I dont have a final gear or tire size. After I break in the motor and run at the track I will need some adjustments. There is no way I am going to drive to the Philly area just for this. I wish that I was closer so I could use you guys and keep EVERYTHING IN HOUSE. Life is not always that easy. I was happy with Joes parts, now that he is under you, WHERE DO I STAND? JD good Luck here on the board. We always need new blood and R&D so dont get a sour taste in your mouth regarding the LS1's. Keep your chin up. Bear
Ditto...
I had Joe Prince's motor installed in my car. He said I would have a 12 month / 24,000 mile warranty. When I picked it up Saturday from JD's Auto (JD) did not mention anything about the warranty and JP did not have any paperwork there for me (as JP was not at the shop). I'm like you Bear... I hope that this all works out. I will let you guys know as things progress.
Old Dec 8, 2003 | 08:51 AM
  #163
ta12sec's Avatar
I was about to buy a set of heads from jpr/jds, thursday night in my email I recived my quote for 600+ more then it says on the website, I emailed and pmed joe and recived no answer. Things like this and then seeing this post have made me seriously consider a diffrent sponser to spend my $$$$ with. Good lucjk ezss and george.
Old Dec 8, 2003 | 04:08 PM
  #164
99 Black Bird T/A's Avatar
13,386 views so far...how fast will that shoot up if links to this thread get posted on other boards?
Old Dec 8, 2003 | 09:12 PM
  #165
ezss's Avatar
I understand this post is going to be locked down shortly, so I do want to say thanks for all the suggestions, insight, etc...
I still cannot understand why JP did not call me back knowing my state of mind, we could have worked something out and all this could have been averted. I think JP can seriously port some cylender heads, but there is more to any sucessful business that just a good product.
I am towing my car home until I can figure out what Im going to do, trusting JD to make sure everything is packed up safely on the flatbed I send for it. I have to work about 60 hours this week, and this is just not worth jeapardizing my job (or my overall happiness) at this point. Hopefully he understands that I just dont have $4k sitting around to fix the car right now.
Erik
Old Dec 8, 2003 | 09:16 PM
  #166
Bear's Avatar
Good Luck. DO NOT GIVE UP!!
Old Dec 8, 2003 | 11:20 PM
  #167
TMar99Z28's Avatar
jumpin jesus that was a lot of reading.
Old Dec 9, 2003 | 12:30 AM
  #168
George C.'s Avatar
IF someone will help me post the "warranty" (HA!!) that Joe sent me today I will show you a part of what I have been dealing with. NOT a single one of you would agree to spending 1000's of $$$ for the heart of your car with a "warranty" like he sent me. Help me post it and read for yourselves. Give me a call at 803-798-7654 if you can help me post a fax to the Internet.
My oil pressure is so low it looks like it is out of oil. I just picked my car up Sat. and on the way home noticed 20psi oil pressure while cruising at 80mph! I can't WAIT to see IF JPR will do anything. From the way Joe is talking he wants me to put in thicker and thicker oil until I get oil pressure. What a joke! I guess at some point the gauge will go up. So... Tues AM my car will be towed to the Chevy dealer to find out what the problem is. If Joe is the guy you all say he is I know he will take care of me and make me whole.
Old Dec 9, 2003 | 09:23 AM
  #169
ezss's Avatar
JD has offered to fix the car for free, with the exception of some assembly labor. I really dont think he thought he would be assuming any bad business liability by taking on Joe Prince, and I totally understand the situation he was put in, but he also understands my situation and doesnt want to see me walk away without having a running car. Everyone loses that way.
He says he will get my car running the way it should have been running from day one, and I think I had a f**king tear in my eye when he told me that. This has been a long and painful year.
Old Dec 9, 2003 | 09:29 AM
  #170
VINCE's Avatar
Shorty Director
JPR should be paying for your assembly labor cost. Much props to JD..
Old Dec 9, 2003 | 09:32 AM
  #171
Mr. B's Avatar
Most excellent news.. damn, what a wringer you're been put through!
JD came though.. like I said in the early post- he didn't seem like a bad guy and was put in a difficult postion by association.
Old Dec 9, 2003 | 09:33 AM
  #172
Bear's Avatar
Way to go JD. This SEEMS like GREAT NEWS!!!
Old Dec 9, 2003 | 09:34 AM
  #173
grb's Avatar
grb
Good Luck. Sounds like you deserve a little!
Old Dec 9, 2003 | 09:49 AM
  #174
7DMACH1's Avatar
Well, maybe now you will all understand what I said about JD before. He got stuck in the middle of this. Glad to hear it's working out. I'm sure JD will deliver what he says. RAY
Old Dec 9, 2003 | 09:52 AM
  #175
Jammer's Avatar
Thats terriffic. It took a little while, and some pressure. Congrats to you and congrats to JD for taking the high road, weather it was his issue or not. I would bet that not only does your car run, but he gives it special attention too.
Old Dec 9, 2003 | 10:34 AM
  #176
grb's Avatar
grb
Anybody else got the sniffles??
Old Dec 9, 2003 | 10:41 AM
  #177
JayLS1-327's Avatar
Good news Eric. I'm glad you got a resolution that you like.
Old Dec 9, 2003 | 01:57 PM
  #178
DaleMX's Avatar
That's Great JD! Way to go! Eric, I know your happy about this!
Old Dec 9, 2003 | 04:00 PM
  #179
JF WS6's Avatar
It's great to hear this will have a happy ending after all. Huge props to JD for stepping up to the plate to help this guy out even though he isn't directly responsible in the first place. That's awesome.
Old Dec 9, 2003 | 05:43 PM
  #180
Mike K.'s Avatar
grats ezss, I am happy to hear this. I would still try to push JPR to pay for the labor as well though.
